6569 Discussions
Can I use 'HETERO Target(CPU,MYRIAD)' on aarch64, ubuntu 18.04
kyusang
Greetings,
Can i use a hetero option of benchmark app on aarch64(ubuntu 18.04)?
Thank you.
Peh_Intel
Hi kyusang,
Yes, you can use HETERO plugin when running Benchmark App on aarch64 platform as long as Open Source OpenVINO™ has been successfully built.
In a meanwhile, I would like to highlight two points here:
  • The pre-built OpenVINO™ package is validated and supported for 32-bit Raspbian OS only.
  • OpenVINO™ ARM CPU plugin is not included in the openvino GitHub repository. It is available as a module inside openvino_contrib GitHub repository. You have to build OpenVINO™ ARM CPU Plugin from source code also if you want to load model to CPU plugin.
Peh
Peh_Intel
Hi kyusang,
This thread will no longer be monitored since we have provided answer. If you need any additional information from Intel, please submit a new question.
Peh
