6572 Discussions
GetPerformanceCounts' result is empty with AUTO plugin
aag
Trying to profile the network ran by our code on Macosx.
GetPerformanceCounts() produces output, as expected, when the network is loaded with "CPU" plugin. Using "AUTO" plugin results in an empty output from GetPerformanceCounts(). Did I miss some configuration that needs to be applied to the plugin?
aag
Looks like while CPU plugin defaults to perf tracking enabled, AUTO plugin isn't -- and has to be properly configured first.
Peh_Intel
Hi aag,
Yes, KEY_PERF_COUNT is set to “NO” by default for CPU, GPU and AUTO plugins.
For CPU plugin, GetPerformanceCounts() can be used even KEY_PERF_COUNT is set to “NO”.
While for GPU and AUTO plugins, you have to change the KEY_PERF_COUNT to “YES” in order to use GetPerformanceCounts().
Peh
Peh_Intel
Hi aag,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Peh
