Can I use OpenVINO-model-server for Deployment in i3 NUC(8th Gen)
Mounagurusamy__Guruv
I am using OpenVINO_2019_R1 to test/learn pedestrian detection and security barrier camera. Please find the system config
OS: Ubuntu 16.04
CPU: Intel® Core™ i3-8109U CPU @ 3.00GHz × 4
RAM:19.5 GiB
Can I use OpenVINO-model-server to deploy and test pedestrian detection and security barrier camera pre-trained models?
Guru
Sahira_Intel
Hi Guru,
Yes, you should be able to. I would however recommend installing the latest version of OpenVINO R3
Sahira .
Sahira_Intel
Hi Guru,
Sahira .
Hi Rizvi,
Thanks for the Quick response.
I tried to install R3, but I got an error(please find the attached screenshot), I couldn't figure out the reason for the error, that's the reason, I have uninstalled R3 and Installed R1.
Can you please let me know, if you could ascertain the problem.
Guru
Kaliyappan__Malathi
My system config is as follows:
OS: Ubuntu 18.10
Processor:Intel® Core™ i3-8109U CPU @ 3.00GHz × 4
Memory:7.7 GiB
I downloaded the OpenVINO Version R3(openvino_2019.3.334)
While running installation scripts I got the Missing optional prerequisites error as in image 1
Then I ran the demo scripts for verifying installation
After running  ./demo_squeezenet_download_convert_run.sh
in the  cd /opt/intel/openvino/deployment_tools/demo path I got the error as in image2.
While building inference engine samples I used ./build_samples.sh  in the  /opt/intel/openvino/deployment_tools/inference_engine/samples/   directory I got the error as in image3.
Can you please clarify me whether the errors are related to Missing optional dependencies in installation process, If so how can I install the prerequisites.
If the errors occured during verification of the scripts, can you help me to solve the errors.
Thanks in advance.
Sahira_Intel
Hi Guru,
Did you try sudo apt-get -f install? Can you attach a screen shot of the output of that if it gives an error?
Best,
Sahira
Hi Rizvi,
We have successfully installed R3 in Ubuntu 18.04 and we are proceeding with OpenVINO model server
https://github.com/IntelAI/OpenVINO-model-server
Guru
