Can not convert tensorflow model to IR.
Singh__Prateek
When I use this script to change the model to IR:
python mo_tf.py --input_model=frozen_inference_graph.pb --tensorflow_object_detection_api_pipeline_config=faster_rcnn_inception_v2_nails_3date_mix.config
I get following errors:
[ ERROR ]  Shape [-1 -1 -1  3] is not fully defined for output 0 of "image_tensor".
 Use --input_shape with positive integers to override model input shapes.
[ ERROR ]  Cannot infer shapes or values for node "image_tensor".        [ ERROR ]  Not all output shapes were inferred or fully defined for node "image_tensor".        For more information please refer to Model Optimizer FAQ (https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html), question #40.
 [ ERROR ]        [ ERROR ]  It can happen due to bug in custom shape infer function <function Parameter.__init__.<locals>.<lambda> at 0x0000027B56DD1708>.
[ ERROR ]  Or because the node inputs have incorrect values/shapes.        [ ERROR ]  Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
[ ERROR ]  Run Model Optimizer with --log_level=DEBUG for more information.        [ ERROR ]  Not all output shapes were inferred or fully defined for node "image_tensor".
When I provide the --input_shape argument then I get:
[ ERROR ]  Shape is not defined for output 0 of "BatchMultiClassNonMaxSuppression/map/while/Slice".
[ ERROR ]  Cannot infer shapes or values for node "BatchMultiClassNonMaxSuppression/map/while/Slice".
[ ERROR ]  Not all output shapes were inferred or fully defined for node "BatchMultiClassNonMaxSuppression/map/while/Slice".
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function Slice.infer at 0x0000029EAD1DA0D8>.
I'm using OpenVino R3: [Model Optimizer version: 2019.3.0-375-g332562022]
The problem persists even when I use --batch instead of --input_shape.I have attached my config file.
