How to use modify yolov3 model
Feng__Zhang
Hi ,
I hava a slim yolov3 model.
I modified some of the channels inside.
Now when I run, using the GPU is slower than using the CPU.
Don't you support the modified model?
Feng__Zhang
I need hlep~~~
Feng__Zhang
nobody  konw?
Shubha_R_Intel
Dear Feng, Zhang,
The fully validated and supported Yolo models we support are documented in our Model Optimizer Yolo Doc. We strongly recommend that you follow these steps to get a working yolo v3 or v2 OpenVino solution.
If you deviate from these instructions, your model may or may not work properly.
Shubha
Shubha_R_Intel
Dear Feng, Zhang,
But by slim do you mean Tensorflow Slim ? Because we support those also. Please check here:
http://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_Slim_Library_Models.html
Shubha
Feng__Zhang
Shubha R. (Intel) wrote:
Dear Feng, Zhang,
Shubha
Hi,Shubha
Thanks for your reply
I mean to compress the model, the model after the pruning operation
