6594 Discussions
Can not init USB device: NC_ERROR in function 'initPlugin'
Kesavaram__Jaiganesh
When i call "detector.setPreferableTarget(cv2.dnn.DNN_TARGET_MYRIAD)" on my python script, i see the below error,
Code:
protoPath = os.path.sep.join([args["detector"], "deploy.prototxt"])
modelPath = os.path.sep.join([args["detector"],
    "res10_300x300_ssd_iter_140000.caffemodel"])
detector = cv2.dnn.readNetFromCaffe(protoPath, modelPath)
Runtime error:
Traceback (most recent call last):
  File "extract_embeddings.py", line 112, in <module>
    vec = embedder.forward()
cv2.error: OpenCV(4.1.0-openvino) /home/jenkins/workspace/OpenCV/OpenVINO/build/opencv/modules/dnn/src/op_inf_engine.cpp:747: error: (-215:Assertion failed) Failed to initialize Inference Engine backend: Can not init USB device: NC_ERROR in function 'initPlugin'
Any help?
i have even followed this instruction for openvino installation,
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html
Garcia__Alberto
Good Afternoon.
Currently I try to run my application (Facial Recognition) on Ubuntu 18.04 + OpenVino_2019.1.144 + OpenCV. When I executed my script I'm geting this error.
E: [ncAPI] [    803652] ncDeviceOpen:672    Failed to find suitable device, rc: X_LINK_DEVICE_NOT_FOUND
  File "recognize_video.py", line 108, in <module>
FATAL: exception not rethrown
Reading in other forums, I followed these instructions but it doesn't solve my problem:
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux.html#additional-NCS-steps
Any suggestion?
Luis_at_Intel
Hi Garcia, Alberto
Based on the error it looks like the program cannot find an NCS device, are you using an NCS stick? If so, make sure you have verified your installation with the verification scripts. This way you can rule out there is an issue with the installation and the device.
If you continue to have issues, please share any details that could help us reproduce (i.e. using NCS/NCS2, python version, powered usb hub, etc.).
Luis
Maksim_S_Intel
1. Make sure you have stick detected:
$ lsusb
Bus 001 Device 007: ID 03e7:2150
Vendor ID is 03e7 and device ID must be something like 2150 or 2485.
2. Then verify permissions, use Bus and Device numbers from previous step:
$ ls -l /dev/bus/usb/001/007
crw-rw---- 1 root users 189, 6 Jan 21 13:06 /dev/bus/usb/001/007
$ id
uid=1000(...) gid=1000(...) groups=1000(...),27(sudo),29(audio),44(video),100(users),...
Group must be users and your current user must be in this group.
