Cannot find alexnet_fp32.xml
biraj__nikit
cannot find alexnet_fp32.xml in C:/Intel folder when I am trying to run
./classification_sample -i <path_to_image>/cat.bmp -m <path_to_model>/alexnet_fp32.xml
Can see other .xml models.
Do we have to download from other source?
Thanks in advance.
Monique_J_Intel
Hi Nikit,
The  FP32 precision .xml file for AlexNet doesn't come in the package. However, we do have model downloader(c:\intel\computer_vision_sdk_2018.*\deployment_tools\model_dwonloader\) that will download the model and then you can convert it using the Model Optimizer(MO) command below to obtain the FP32 precision .xml file.
Downloader command:
python3 downloader.py --name alexnet
MO conversion:
python3 mo.py --input_model alexnet.caffemodel
Kind Regards,
Monique Jones
biraj__nikit
Thanks for the post.
But when I initiated the command
.\classification_sample.exe -i C:\Users\Admin\Desktop\image1.jpg -m C:\Intel\computer_vision_sdk_2018.4.420\deployment_tools\model_optimizer\alexnet.xml
I get nothing on command prompt. I won't see any classified image dumped or any pop up window opens.
Attaching file for your reference.
Thanks in advance.
wu__sunny
I have the same problem. Everything is okay but no output.
Truong__Dien_Hoa
New Contributor II
I don't use window but I can confirm it works in ubuntu.
Output should be like below:
Top 10 results:
Image /home/cat.png
285 0.5423567 label #285
281 0.1195140 label #281
282 0.0565354 label #282
330 0.0535832 label #330
356 0.0411474 label #356
278 0.0267688 label #278
333 0.0241656 label #333
280 0.0215378 label #280
298 0.0198837 label #298
904 0.0119953 label #904
total inference time: 41.3414165
Average running time of one iteration: 41.3414165 ms
Throughput: 24.1888180 FPS
[ INFO ] Execution successful
