Missing OpenVino toolkit samples
TStoy
Hi community, I installed the Intel® Distribution of OpenVINO™ toolkit. Everything seems to be okay, except one thing. The toolkit samples are missing. I checked the inference_engine_samples/intel64/Release folder and found only these two, mentioned in the Get started page. Thanks in advance!
nikos1
Valued Contributor I
Hello Stoyanov, Tsvetelin
Typically in the  inference_engine_samples/intel64/Release folder you can find the binaries of the samples after you build them from source. Have you tried building them? if not please follow instructions  in file Intel/computer_vision_sdk_2018.5.445/deployment_tools/documentation/_docs_IE_DG_Samples_Overview.html
For example for Windows
The recommended Windows build environment is the following:
Microsoft Windows* 10
Microsoft* Visual Studio* 2015 including Microsoft Visual Studio 2015 Community or Microsoft Visual Studio 2017
CMake* version 2.8 or later
OpenCV* 3.3 or later
Generate Microsoft Visual Studio solution file using create_msvc_solution.bat file in the samples directory and then build the solution samples\build\Samples.sln in the Microsoft Visual Studio 2015.
nikos
nikos1
nikos
