6597 Discussions
Compilation Error while installing OpenCV with OpenVino
Adavani__Santi
I am trying to install OpenCV with OpenVino bindings using installation instructions here on AI Builder colfax cluster.
My cmake command is as follows based on instructions.
cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/home/u15909/local/opencv_intel/ -DWITH_INF_ENGINE=ON -DINTEL_CVSDK_DIR="/home/u15909/intel/computer_vision_sdk_2018.2.300/deployment_tools/" -DIE_PLUGINS_PATH="/home/u15909/intel/computer_vision_sdk_2018.2.300/deployment_tools/inference_engine/lib/centos_7.4/intel64/"  ..
Error from make -j8
[ 71%] Linking CXX executable ../../bin/opencv_test_dnn
../../lib/libopencv_dnn.so.3.4.2: undefined reference to
`InferenceEngine::Data::Data(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&,
std::vector<unsigned long, std::allocator<unsigned long> > const&,
InferenceEngine::Precision, InferenceEngine::Layout)'
Appreciate any help in resolving this error.
Santi
Maksim_S_Intel
you have to enable C++11: -DENABLE_CXX11=ON
Adavani__Santi
I see the same error after enabling C+11.
../../lib/libopencv_dnn.so.3.4.2: undefined reference to `InferenceEngine::Data::Data(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<unsigned long, std::allocator<unsigned long> > const&, InferenceEngine::Precision, InferenceEngine::Layout)'
Maksim_S_Intel
First try to make a clean build, if it does not help, please post more information about your configuration: OpenCV version, OpenVino version, OS, platform, compiler, etc.; attach cmake output log during clean build.
Did you use Docker for building? If yes, please attach the Dockerfile.
