Does ncsdk support aarch64/arm64?
The install.sh script use /opt/movidius/NCSDK/ncsdk-$(eval uname -m) as library,
my hardware is aarch64(which I think is arm64), but the there are only "ncsdk-x86_64" and "ncsdk-armv7l" listed in the install dir.
I've tried change to Used armv7l instead and python throws "libmvnc.so: Wrong ELF class: ELSCLASS32", which is expected because armv7 is 32 and my arch is arm64
Anything I missed? Or movidius sdk not support aarch64
I'm here to answer my problem.
Fixed it by build from src/api , not install.sh
@chenxiaoyu3 How you fix it?
I have the same problem
