6597 Discussions
Compile Keras MobileNetV2 model to Movidius graph file
I am having some problems when compiling models from Keras Application to Movidius graph file.
What I did:
  1. save model
    from keras.applications import MobileNetV2, VGG16, MobileNet from keras import backend as K mn = MobileNet() saver = tf.train.Saver() sess = K.get_session() saver.save(sess, "./mv2") tf.train.write_graph(sess.graph_def, ".", "graph.pbtxt")
  2.
  3. use Tensorflow script to create a frozen graph
    python -m tensorflow.python.tools.freeze_graph --clear_devices --input_graph graph.pbtxt --input_checkpoint mv2 --output_node_names "reshape_2/Reshape" --output_graph graph.frozen.pb
  4.
  5. convert the frozen graph to Movidius graph
    mvNCCompile -s graph.frozen.pb -in=input_3 -on=reshape_2/Reshape
  6.
Then mvNCCompile throws: [Error 5] Toolkit Error: Stage Details Not Supported: FusedBatchNorm inputs mean and variance are not defined. The graph is not created for inference.
If I do the exactly the same thing for VGG16, which means replacing "mn=MobileNet()" with "mn=VGG16()", everything works perfectly, so I am assuming the error has something to do with the BatchNorm layers used in MobileNet? Any suggestion on how I can get rid of this error?
ok, now we get that NCSDK does not support keras
any news about this? I'm having a similar issue!
