Hi, I'm try to compile this model for the intel compute stick.
I've run the download_weights.py for download the caffe model and i've run
mvNCCompile train.prototxt -w res10_300x300_ssd_iter_140000_fp16.caffemodel -o face_graph
but i've this error:
/usr/lib/python3/dist-packages/scipy/stats/morestats.py:16: DeprecationWarning: Importing from numpy.testing.decorators is deprecated, import from numpy.testing instead.
from numpy.testing.decorators import setastest
/usr/lib/python3.5/importlib/_bootstrap.py:222: RuntimeWarning: numpy.dtype size changed, may indicate binary incompatibility. Expected 96, got 88
return f(*args, **kwds)
mvNCCompile v02.00, Copyright @ Intel Corporation 2017
WARNING: Logging before InitGoogleLogging() is written to STDERR
F0613 09:57:36.231927 192 insert_splits.cpp:29] Unknown bottom blob 'data' (layer 'data_bn', bottom index 0)
*** Check failure stack trace: ***
Aborted (core dumped)
I don't know how to resolve. Have somebody some clue?
Hello FDeSi,
Thank you for posting on the Intel ® communities.
Before I can assist you further I will need to know the exact model of Intel ® Compute Stick you have.
David V
Thank you for reply.
I've the Movidius Neural Compute Stick, the first model, but i'm using the ncsdk2 in a docker image.
Hello FDeSi,
Thank you for your response.
I am changing the topic to the appropriate support forum, you will get assistance as soon as possible.
David V
Hi Francesco,
I apologize for the delay in my response. This error is caused by compiling a deploy-mode model with a train-mode weight. Instead of using train.prototxt, use deploy.prototxt.
Sahira
