Configure the Model Optimizer
Aman_Vishen
When i install tensorFlow it ask for specific version of numpy so i install that version but when when i install mxnet it again ask for different version of numpy
there is numpy compatibility issue
Error code--
ERROR: After October 2020 you may experience errors when installing or updating packages. This is because pip will change the way that it resolves dependency conflicts.
We recommend you use --use-feature=2020-resolver to test your packages with the new resolver before it becomes the default.
tensorboard 2.3.0 requires requests<3,>=2.21.0, but you'll have requests 2.18.4 which is incompatible.
Iffa_Intel
Greetings,
First and foremost, can you clarify whether you are using TF1 or TF2?
If you are using TF2, you can refer here to ensure correct setup:
Since you mentioned mxnet, I presume you are trying to convert mxnet model to IR and use it with Openvino. Please help to refer to this official documentation to ensure your custom model is supported: https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_MxNet.html
By default, if you had done the install_prerequisites.sh correctly, you won't have any problems afterwards :https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_Config_Model_Optimizer.html
probably you can try to do it manually bu running:
install_prerequisites_mxnet.sh for Linux
install_prerequisites_mxnet.bat for Windows
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
