6593 Discussions
Converting Caffe and YOLOv3/YOLOv4 Models to OpenVINO IR (2024)
king123
I need guidance on converting Caffe Models and YOLOv3/YOLOv4 Darknet models to OpenVINO IR using Openvino 2024 OVC. Any help would be appreciated.
Aznie_Intel
Hi King123,
Thanks for reaching out. You may refer to this Convert to OpenVINO Intermediate Representation (IR) for the conversion's command lines and code examples. However, OpenVINO support for Caffe model is currently deprecated in the OpenVINO 2024 version. If you insist on converting the Caffe model into OpenVINO IR, you may use OpenVINO 2022.3.
Hope this helps.
Aznie
king123
Is it okay to use caffe model converted to IR using openvino 2022 version in the 2024 version for inference?
Aznie_Intel
Hi King123,
No. You must use the Intermediate Representation (IR) file generated from the same OpenVINO version.
Aznie
Aznie_Intel
Hi King123,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
