6593 Discussions
Converting TensorFlow to OpenVINO can't work with openvino-dev==2022.1.0
Mostafa-
While trying to run the notebook from GitHub, I got the below error.
https://github.com/openvinotoolkit/openvino_notebooks/tree/main/notebooks/101-tensorflow-to-openvino
ModuleNotFoundError: No module named 'tensorflow.python'
The error resolved when installing openvino[tensorflow].
pip install openvino-dev[tensorflow2]
the question is why it doesn't run when installing openvino-dev==2022.1.0?
Mostafa
Wan_Intel
Hi Mostafa-,
Thanks for pointing out the error.
For your information, in the latest commit, we have updated the requirements file.
pip install -r requirements.txt
Collecting openvino-dev[onnx,tensorflow2]==2022.1.0
Downloading openvino_dev-2022.1.0-7019-py3-none-any.whl (5.8 MB)
Wan
Wan_Intel
Hi Mostafa,
May I know which operating system are you using on your end?
For your information, you may refer to the Installation Guide to install the required files for your operating system or environment before starting OpenVINO™ Notebooks.
Hope it helps.
Wan
Mostafa-
I am running these notebook on Windows 10.
I did install the requirements.txt file and it contains openvino.
Mostafa
Wan_Intel
Hi Mostafa-,
Wan
Wan_Intel
Hi Mostafa-,
Thank you for your question.
If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Wan
