DL Streamer python sample not running
Shantanu_Bakare
I am trying to run DL Streamer on Intel GPU.
I am working with a Ubuntu 18.04 running on an Intel i7 8th Gen CPU and 16 GB RAM machine. OpenVino Version is 2021.3.394. The complete installation was done as per official documentation and all the drivers were installed properly.
In this env, I tried running dl streamer python sample and it ran properly(refer to image_1.png). Then I tried running it again by changing the device, for GST pipeline elements, from CPU to GPU in the code(refer to image_2.png). It gave no errors or anything but there was no output window(refer to image_3.png).
What might be the problem here?
IntelSupport
Community Manager
Hi Shantanu_Bakare,
We have validated the python sample for both CPU and GPU without any issue. Inference on GPU might take a longer time to load compared with CPU. I would advise you to install a GPU driver based on this documentation then execute the same command.
./draw_face_attributes.sh
Aznie
IntelSupport
Community Manager
Hi Shantanu_Bakare,
We are currently investigating this issue and will get back to you with the information soon.
Aznie
IntelSupport
Community Manager
Hi Shantanu_Bakare,
Aznie
Shantanu_Bakare
The problem was not related to drivers. It was related to model loading time.
CPU model takes around 2-3 secs to load on the machine I am using, but the GPU model takes around 80-100 secs.
Earlier I observed it for around 30-40 secs and thought that there might be some issue.
Thanks for the help.
IntelSupport
Community Manager
Hi Shantanu_Bakare,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Aznie
