DL Workbench error (Illegal instruction (core dumped))
Kalimullin__Fanis
Trying to run DL Workbench using docker:
docker run --rm -p 5665:5665 --name workbench --privileged -v /dev/bus/usb:/dev/bus/usb -v /dev/dri:/dev/dri -PROXY_HOST_ADDRESS=0.0.0.0 -e PORT=5665 -it openvino/workbench:latest
But it hangs forever with messages: 'Celery is not ready to the moment. Retry in 2 seconds'
My small investigation is that entrypoint.package.sh tries to run celery worker but it fails with the message: 'Illegal instruction (core dumped)'. I suppose it's because target CPU (N4200) doesn't support AVX instructions set.
Could you recommend workaround to fix this issue?
Shubha_R_Intel
Dear Kalimullin, Fanis,
Sorry you're having trouble. We are looking into this.
Shubha
Peter_L_Intel
Hi Shubha, Fanis,
Was there any resolution to this? I see celery trapping invalid opcodes from the libmxnet.so module distributed with Python from dmesg output. It's not obvious how this can be changed to SSE from AVX which would be suitable for Atom.
JesusE_Intel
Hi Pete,
I was able to run the DL workbench with the following command. I did see the Celery message as above but the web GUI was still accessible.
docker run -p 127.0.0.1:5665:5665 \
                --name workbench \
                --privileged \
                -v /dev/bus/usb:/dev/bus/usb \
                -v /dev/dri:/dev/dri \
                -e PROXY_HOST_ADDRESS=0.0.0.0 \
                -e PORT=5665 \
Could you share additional information about the system you are using?
Jesus
Peter_L_Intel
Hi Jesus,
Same as the issue reporter, Atom N4200, 4 core, 1.1HGz Pentium branded. 4GB RAM: https://ark.intel.com/content/www/us/en/ark/products/95592/intel-pentium-processor-n4200-2m-cache-up-to-2-5-ghz.html
My start command is the same as yours.
Pete
