6585 Discussions
Demo 1 stuck on line 'Loading model' using MYRIAD
Meharwade__Rushikesh
Hi Team,
I recently purchased NCS2 device, for POC required by one of the well known CAR manufacturing company. For me demo's are working with -d CPU option but when I run it with -d MYRIAD argument, my command line is stuck infinitely on 'Loading the model to the plugin' text. Same command has worked only one time previously. I am using Window 10 in this case. Can someone help me to debug this?
Below is the complete output:
[ INFO ] InferenceEngine:
        API version ............ 1.4
        Build .................. 19154
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     C:\Intel\computer_vision_sdk_2018.5.456\deployment_tools\demo\\car.png
[ INFO ] Loading plugin
        API version ............ 1.5
        Description ....... myriadPlugin
[ INFO ] Loading network files:
        C:\Users\rushi\Documents\Intel\OpenVINO\openvino_models\ir\FP16\classification\squeezenet\1.1\caffe\squeezenet1.1.xml
        C:\Users\rushi\Documents\Intel\OpenVINO\openvino_models\ir\FP16\classification\squeezenet\1.1\caffe\squeezenet1.1.bin
[ INFO ] Preparing input blobs
[ WARNING ] Image is resized from (787, 259) to (227, 227)
[ INFO ] Batch size is 1
[ INFO ] Preparing output blobs
[ INFO ] Loading model to the plugin
This program is not going beyond this line.
Shubha_R_Intel
Under deployment_tools\inference_engine\external\MovidiusDriver\ there is a Movidius_VSC_Device.inf
Did you right-click and Install ?
Yes Shubha, I installed drivers too. Tried it multiple times. First time it required a restart now it just says 'Operation completed successfully'.
As it comes to 'Loading model to plugin' step, within drivers it changes its name to 'VSC Loopback device' too.
nikos1
Valued Contributor I
Hello Rushikesh,
Had a similar issue on Linux (hang after NCS plug-in load) and in my case it was because I forgot to copy the ./mvnc folder that had files the NCS needed.
Could you check if you have the ./mvnc folder in the same place where you load the myriad plug-in (dll or so) from .
Cheers,
nikos
Hi Niko and Shubha , thanks for helping but my problem got resolved automatically after plugging in device after 2 days without any changes. I will reopen the thread in case of similar concern.
