I try to run inside Docker classification example on Python:
python dldt/inference-engine/ie_bridges/python/sample/classification_sample/classification_sample.py -m inceptionv3-int8-tf-0001.xml -i cat.jpg
and get:
[ INFO ] Creating Inference Engine [ INFO ] Loading network files: inceptionv3-int8-tf-0001.xml inceptionv3-int8-tf-0001.bin Traceback (most recent call last): File "classification_sample.py", line 135, in <module> sys.exit(main() or 0) File "classification_sample.py", line 68, in main supported_layers = ie.query_network(net, "CPU") File "ie_api.pyx", line 101, in openvino.inference_engine.ie_api.IECore.query_network RuntimeError: Device with "CPU" name is not registered in the InferenceEngine
Although, I run it on Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz.
Dockerfile:
FROM python:3.7 RUN apt-get update && apt-get install -y --no-install-recommends \ wget \ git \ build-essential \ cmake \ curl \ wget \ libssl-dev \ ca-certificates \ git \ libboost-regex-dev \ gcc-multilib \ g++-multilib \ libgtk2.0-dev \ pkg-config \ unzip \ automake \ libtool \ autoconf \ libcairo2-dev \ libpango1.0-dev \ libglib2.0-dev \ libgtk2.0-dev \ libswscale-dev \ libavcodec-dev \ libavformat-dev \ libgstreamer1.0-0 \ gstreamer1.0-plugins-base \ libusb-1.0-0-dev \ libopenblas-dev \ libpng-dev WORKDIR /opt ARG OPENCV_VERSION="4.2.0" ENV OPENCV_VERSION $OPENCV_VERSION RUN pip install numpy RUN curl -Lo opencv.zip https://github.com/opencv/opencv/archive/${OPENCV_VERSION}.zip && \ unzip -q opencv.zip && \ curl -Lo opencv_contrib.zip https://github.com/opencv/opencv_contrib/archive/${OPENCV_VERSION}.zip && \ unzip -q opencv_contrib.zip && \ rm opencv.zip opencv_contrib.zip && \ cd opencv-${OPENCV_VERSION} && \ mkdir build && cd build && \ cmake -D CMAKE_BUILD_TYPE=RELEASE \ -D CMAKE_INSTALL_PREFIX=/usr/local \ -D OPENCV_EXTRA_MODULES_PATH=../../opencv_contrib-${OPENCV_VERSION}/modules \ -D WITH_JASPER=OFF \ -D BUILD_DOCS=OFF \ -D BUILD_EXAMPLES=OFF \ -D BUILD_TESTS=OFF \ -D BUILD_PERF_TESTS=OFF \ -D BUILD_opencv_java=NO \ -D BUILD_opencv_python=YES \ -D BUILD_opencv_python2=NO \ -D BUILD_opencv_python3=YES \ -D PYTHON3_EXECUTABLE=$(which python3.7) \ -D PYTHON_INCLUDE_DIR=/usr/local/include/python3.7m \ -D PYTHON_LIBRARY=/usr/local/lib/libpython3.7m.so \ -D PYTHON3_NUMPY_INCLUDE_DIRS=/usr/local/lib/python3.7/site-packages/numpy/core/include/ \ -D OPENCV_GENERATE_PKGCONFIG=ON .. && \ make -j $(nproc --all) && \ make preinstall && make install && ldconfig && \ cd / && rm -rf opencv* RUN git clone https://github.com/opencv/dldt.git && \ cd dldt && \ cd inference-engine && \ git submodule init && \ git submodule update --recursive RUN pip install -r dldt/inference-engine/ie_bridges/python/requirements.txt RUN cd dldt/inference-engine && \ mkdir build && cd build && \ cmake \ -DCMAKE_BUILD_TYPE=Release \ -DENABLE_CLDNN=OFF \ -DENABLE_MKL_DNN=OFF \ -DENABLE_PYTHON=ON \ -DPYTHON_EXECUTABLE=`which python3.7` \ -DPYTHON_LIBRARY=/usr/local/lib/libpython3.7m.so \ -DPYTHON_INCLUDE_DIR=/usr/local/include/python3.7m .. && \ make --jobs=$(nproc --all) RUN export PYTHONPATH="$PYTHONPATH:/opt/dldt/inference-engine/bin/intel64/Release/lib/python_api/python3.7"
What am I doing wrong?
Output of hello_query_device.py: python hello_query_device/hello_query_device.py Available devices:
Replacement of -DENABLE_MKL_DNN=OFF on -DENABLE_MKL_DNN=ON helped.
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
Topic Options
