6597 Discussions
Different outputs from Myraid X and Myriad 2
lin__dia
system: Ubuntu 16.04, OPENVINO R4/R5
I try to make a experiment of implementing "multitask" network on Myraid X, but I get the wrong output. Following are my steps to get the incorrect output.
I use an age classification implemented on Caffe as my experiment which contains the prototxt and weights
I made some modification of the prototxt by copying the last fc layer 'fc8' and weights as following to create a two tasks network,
layers {
  type: INNER_PRODUCT
  bottom: "fc7"
  top: "fc8"
  inner_product_param {
    num_output: 8
layers {
  type: SOFTMAX
  bottom: "fc8"
  top: "prob"
layers {
  type: INNER_PRODUCT
  bottom: "fc7"
  top: "copy_fc8"
    num_output: 8
layers {
  type: SOFTMAX
  bottom: "copy_fc8"
  top: "copy_prob"
Here we get the same layer of 'fc8' and 'copy_fc8', therefore, I should get the same output from these two softmax layer.
The input image is downloaded from google image search.
1.
I use model optimizer of R4 to convert the caffe model to get IR model and run it on Myraid 2.
I get the two same outputs of the input image as expectation,
copy_fc8:
[ INFO ] -------
[ INFO ] 0.000357389
[ INFO ] 0.00239372
[ INFO ] 0.0594482
[ INFO ] 0.0129318
[ INFO ] 0.273193
[ INFO ] 0.260742
[ INFO ] 0.0244904
[ INFO ] 0.366211
fc8:
[ INFO ] -------
[ INFO ] 0.00239372
[ INFO ] 0.0594482
[ INFO ] 0.0129318
[ INFO ] 0.273193
[ INFO ] 0.260742
[ INFO ] 0.0244904
[ INFO ] 0.366211
2.
I use model optimizer of R4 to convert the caffe model to get IR model and run it on Myraid X.
I get the two different outputs of the input image and the output from 'copy_fc8' seems correct which is similar to the experiment 1.,
copy_fc8:
[ INFO ] -------
[ INFO ] 0.00031805
[ INFO ] 0.00197792
[ INFO ] 0.0588989
[ INFO ] 0.0136337
[ INFO ] 0.271484
[ INFO ] 0.260742
[ INFO ] 0.0244141
[ INFO ] 0.368896
fc8:
[ INFO ] -------
[ INFO ] 0.0452271
[ INFO ] 0.039978
[ INFO ] 0.0336609
[ INFO ] 0.108032
[ INFO ] 0.300049
[ INFO ] 0.322998
[ INFO ] 0.10144
[ INFO ] 0.0483398
3.
I use model optimizer of R5 to convert the caffe model to get IR model and run it on Myraid 2.
I also get the two same outputs of the input image as expectation,
copy_fc8:
[ INFO ] -------
[ INFO ] 0.00239372
[ INFO ] 0.0594482
[ INFO ] 0.0129318
[ INFO ] 0.273193
[ INFO ] 0.260742
[ INFO ] 0.0244904
[ INFO ] 0.366211
fc8:
[ INFO ] -------
[ INFO ] 0.00239372
[ INFO ] 0.0594482
[ INFO ] 0.0129318
[ INFO ] 0.273193
[ INFO ] 0.260742
[ INFO ] 0.0244904
[ INFO ] 0.366211
4.
I use model optimizer of R5 to convert the caffe model to get IR model and run it on Myraid X.
I also get the two different outputs of the input image and all outputs are different from the experiment 2.,
copy_fc8:
[ INFO ] -------
[ INFO ] 0.00029707
[ INFO ] 0.000290632
[ INFO ] 0.00393295
[ INFO ] 0.0123291
[ INFO ] 0.0689697
[ INFO ] 0.652832
[ INFO ] 0.0205231
[ INFO ] 0.240723
fc8:
[ INFO ] -------
[ INFO ] 0.0509949
[ INFO ] 0.0478516
[ INFO ] 0.0298309
[ INFO ] 0.104431
[ INFO ] 0.28833
[ INFO ] 0.334717
[ INFO ] 0.0968628
[ INFO ] 0.046936
What happened to the Myraid X to get the inconsistent outputs in comparison to Myraid 2 when I run the model of R4 or R5 ?
