Hi
I downloaded FPGA binaries from the link given in section "Running the SqueezeNet* sample on FPGA". When i use it, it throws following error.
Emulator Context callback: Program was compiled for a different board.
aocx is for board pac_a10 whereas device is a10gx
Use aocl program to safely transition to the new board
How do i get around this issue ?
Yatish
Found corresponding binaries in /opt/intel/computer_vision_sdk/a10_devkit_bitstreams/ .
Can you help me for the 'Program the Intel® Arria® 10 GX FPGA Development Kit'
I am installing the openvino with Linux FPGA support, I followed all the steps (which given on Intel website) to program the FPGA I successfully executed 'quartus_pgm -c 1 -m JTAG -o "p;top.sof' this file but the problem is here:-
When i ran "quartus_pgm -c 1 -m JTAG -o "p;max5_150.pof@2" i is throwing the error which is mentioned below:-
Device index 1 must be less than device index of physical JTAG chain. check board or choose legal device index '
Can you help me to sort out this error
