I created and trained a Keras YOLO v3 model and tested it on CPU and NCS1 with similar results but big differences in speed. As NCS1 is discontinued, I got an NCS2 to test the same IR, and, surprisingly results changed dramatically.
I'm using openvino 2020r4 in a macos Catalina with Python 3.7.7 and tensorflow 1.15
For freezing the model I used the code:
I converted the pb model with
Is there any special reason for this difference?
Is there any way to get the same results?
I turned off VPU_HW_STAGES_OPTIMIZATION and looks like everything is ok now.
can you please tell where can we find a description of those parameters effect? I found this, but it is not too clarifier
https://docs.openvinotoolkit.org/latest/openvino_docs_IE_DG_supported_plugins_VPU.html
Thanks a lot
Hi pjvazquez,
Thanks for reaching out. Please try to add --reverse_input_channels to your model optimizer command. Could you provide the output on the Intel Movidius Neural Compute Stick, Intel Neural Compute Stick 2 and CPU for comparison? Also, would it be possible to share your frozen TensorFlow model to reproduce on my end?
Jesus
Thanks, I included the --reverse_input_channels in the mo command and I'm testing it.
Now I can not give you both outputs, I'm testing the system.
This is the link to the TF frozen pb file (200MB)
Hi pjvazquez,
Thanks for sharing the TensorFlow frozen model, I was able to convert to OpenVINO IR format. However, I was not able to test using our Yolo V3 demo application as the model seems to have a different architecture than the supported Darknet implementation of Yolo V3.
For debug purposes, could you try turning off VPU_HW_STAGES_OPTIMIZATION? In Python, place the following line before loading the network.
ie.set_config({'VPU_HW_STAGES_OPTIMIZATION': 'NO'}, "MYRIAD")
Jesus
Hi Jesus, yes, I'll do it.
You are right, the YOLO model was implemented in Keras based on this repo:
https://github.com/pjvazquez/head-detection-using-yolo
Next week I'll be able to obtain the outputs from both sticks and have data to compare them.
Thanks a lot
Hi pjvazquez,
The VPU_HW_STAGES_OPTIMIZATION is only meant to be used for internal debug purposes. We are working on updating the documentation and API. Models that run correctly after turning VPU_HW_STAGES_OPTIMIZATION off may likely be a bug. However, in this case, the YOLOv3 model you are using has not been validated with OpenVINO.
Hope this answers your question.
Jesus
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
![](/skins/images/7746D4550810124E96DD2FD9957552B1/responsive_peak/images/icon_anonymous_message.png)
