Documentation of repeated_type and getRepeatedMetaDataByName()
Deepak_C_R
I was going through the cnn_custom_kernel sample code.
I have found the structure repeated_type and the function getRepeatedMetaDataByName().
But in the header file, the documentation is not explaining properly, It's having only following:
        Utility function used for retriveing repeated metadata objects by their names
        * \param [in] custom_layer_descriptor descriptor
        * \param [in] name of the metadata as defined in the prototxt parameter
        \returns repeated_type object
        KERNELS_UTILS_API repeated_type getRepeatedMetaDataByName(custom_layer_descriptor desc, const char* name);
Can somebody help me to what getRepeatedMetaDataByName() is doing and the variables in repeated_type ?
Thank You.
Maxim_S_Intel
this function is for retrieving parameters, that might have multiple values.
E.g. "offset: 20, 24". So you get the parameter by name, then get numbers of values, and then retrieve value by  value.
Deepak_C_R
Thank you Maxim Shevtsov.
