6574 Discussions
Does OpenVINO support the TensorDot in the TensorFlow?
zhe__pang
I try to use the optimizer to generate IR but got the following ERROR
[ ERROR ]  Unexpected exception happened during extracting attributes for node fclayer10/Tensordot/Prod_1.
Original exception message: 19
TensorFlow Version: 1.11.0
Model Optimizer version:     2019.1.0-341-gc9b66a2
Shubha_R_Intel
Dear zhe, pang,
The OpenVino Supported Layers Doc does not mention TensorDot. But your error message seems suspicious:
Usually "Original Exception message" means that Model Optimizer is merely reporting an exception, rather than throwing the exception itself.
Can you kindly tell me more about your model ? Where are you getting this model, or is it one you've constructed from scratch ? Also, what mo_tf.py command are you using ? Finally, I hope you are using OpenVino 2019R2, which was just recently released.
Shubha
