6577 Discussions
Does OpenVINO2022.x support QuantizeLinear/DequantizeLinear?
North-man
My post is a similar issue to the post below.
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/openVino-inference-using-onnx-model/m-p/1460146
I believe OpenVINO supports QuantizeLinear/DeauantizeLinear layers and ONNX format models.
However, the model using QuantizeLinear/DeauantizeLinear layers (=Model1) gives different results depending on the OpenVINO 2021.4 and 2022.3.
For comparison, the model that does not use QuantizeLinear/DeauantizeLinear (=Models2) gives the same result for OpenVINO 2021.4 and 2022.3.
For further comparison, I also compared results when using different inference frameworks (e.g. TensorRT).
The conditions are as follows.
・model format is onnx.
・Windows10 and C++.
・output size = 1000 (using Generic imageNet)
The results are summarized below.
・The numbers in the table below are the first 10 of 1000
  OpenVINO
2021.4
OpenVINO
2022.3
Other framework
(TensorRT)
use QuantizeLinear/DeauantizeLinear (=Model1) 1.82228 2.83418 1.84796
-5.29731 -3.76114 -5.31353
-2.57535 -3.80294 -2.56074
0.815923 0.491049 0.816834
-5.83255 -4.85166 -5.85728
-3.84568 -1.81016 -3.84114
-4.65202 -5.18312 -4.6788
3.07942 1.29188 3.09532
2.51693 1.51579 2.54098
10.021 6.2427 10.0298
does not use
QuantizeLinear/DeauantizeLinear (=Model2)
1.92688 1.92688 1.92688
-4.5917 -4.5917 -4.5917
-3.09134 -3.09134 -3.09134
0.355102 0.355103 0.355103
-6.01955 -6.01955 -6.01955
-4.48821 -4.48821 -4.48821
-5.00235 -5.00235 -5.00235
2.16591 2.16591 2.16591
2.74276 2.74276 2.74276
11.9108 11.9108 11.9108
Only the combination of the model using QuantizeLinear/DeauantizeLinear and OpenVINO2022.3 has a large numerical difference.
Why is this?
Please let me know if you get similar results in your environment and if so what the problem is.
I wanted to attach the model and the input image, but it was not possible due to size restrictions. Please let me know if there is a better way.
Thank you for your support.
Wan_Intel
Hi North-man,
Yes, QuantizeLinear and DequantizeLinear are supported as shown in ONNX Supported Operators in Supported Framework Layers.
Please share the required files with us via the following email so we can replicate the issue:
waix.fook.wan@intel.com
Wan
Wan_Intel
Hi North-man,
Thanks for your information.
We've received the required files via email. We'll investigate this issue and we'll update you at the earliest.
Wan
Wan_Intel
Hi North-man,
Thanks for your patience.
I've validated Model1 and Model2 ONNX models with Hello Classification Python Sample from OpenVINO™ toolkit 2021.4.2 and Hello Classification Python Sample from OpenVINO™ toolkit 2022.3 using Zebra-1_227x227.jpg as an input image.
Model1 ONNX model (uses QuantizeLinear and DequantizeLinear) :
Result when using OpenVINO™ toolkit 2021.4.2 : -1.9281068
Result when using OpenVINO™ toolkit 2022.3    : 0.30328402
Model2 ONNX model (does not use QuantizeLinear and DequantizeLinear):
Result when using OpenVINO™ toolkit 2021.4.2 : -54.98152
Result when using OpenVINO™ toolkit 2022.3    : -54.981552
We do notice the results are different when using the ONNX model that uses QuantizeLinear and DequantizeLinear.
On another note, could you please share your script with us so we can reproduce the same inference result from our end for further investigation? From your results, we would like to know if the results that are approximately 1.92688 is the correct or expected result.
Wan
References:
North-man
Hi, Wan-Intel
Thank you for your response.
Some parts of my script cannot be published, so I will consider a script that can be reproduced.
Please wait.
North-man
Wan_Intel
Hi North-man,
Noted. Take your time to provide us required files to replicate the issue so we can further investigate the issues.
Wan
North-man
Hi Wan,
I have one question about your answer above.
What does a number like -1.9281068 show?
The sample below appears to display the Top 10.
North-man
Wan_Intel
Hi North-man,
I've edited Hello Classification Python Sample for both OpenVINO™ toolkit 2021.4.2 and OpenVINO™ toolkit 2022.3 to display the results above. I've attached both Python scripts in this thread.
edited_hello_classification_2021
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# Copyright (C) 2018-2021 Intel Corporation
# SPDX-License-Identifier: Apache-2.0
import argparse
import logging as log
import sys
import cv2
import numpy as np
from openvino.inference_engine import IECore
def parse_args() -> argparse.Namespace:
    """Parse and return command line arguments"""
    parser = argparse.ArgumentParser(add_help=False)
    args = parser.add_argument_group('Options')
    # fmt: off
    args.add_argument('-h', '--help', action='help', help='Show this help message and exit.')
    args.add_argument('-m', '--model', required=True, type=str,
                      help='Required. Path to an .xml or .onnx file with a trained model.')
    args.add_argument('-i', '--input', required=True, type=str, help='Required. Path to an image file.')
    args.add_argument('-d', '--device', default='CPU', type=str,
                      help='Optional. Specify the target device to infer on; CPU, GPU, MYRIAD, HDDL or HETERO: '
                      'is acceptable. The sample will look for a suitable plugin for device specified. '
                      'Default value is CPU.')
    args.add_argument('--labels', default=None, type=str, help='Optional. Path to a labels mapping file.')
    args.add_argument('-nt', '--number_top', default=10, type=int, help='Optional. Number of top results.')
    # fmt: on
    return parser.parse_args()
def main():
    log.basicConfig(format='[ %(levelname)s ] %(message)s', level=log.INFO, stream=sys.stdout)
    args = parse_args()
    # ---------------------------Step 1. Initialize inference engine core--------------------------------------------------
    log.info('Creating Inference Engine')
    ie = IECore()
    # ---------------------------Step 2. Read a model in OpenVINO Intermediate Representation or ONNX format---------------
    log.info(f'Reading the network: {args.model}')
    # (.xml and .bin files) or (.onnx file)
    net = ie.read_network(model=args.model)
    if len(net.input_info) != 1:
        log.error('Sample supports only single input topologies')
        return -1
    if len(net.outputs) != 1:
        log.error('Sample supports only single output topologies')
        return -1
    # ---------------------------Step 3. Configure input & output----------------------------------------------------------
    log.info('Configuring input and output blobs')
    # Get names of input and output blobs
    input_blob = next(iter(net.input_info))
    out_blob = next(iter(net.outputs))
    # Set input and output precision manually
    net.input_info[input_blob].precision = 'U8'
    net.outputs[out_blob].precision = 'FP32'
    # Get a number of classes recognized by a model
    num_of_classes = max(net.outputs[out_blob].shape)
    # ---------------------------Step 4. Loading model to the device-------------------------------------------------------
    log.info('Loading the model to the plugin')
    exec_net = ie.load_network(network=net, device_name=args.device)
    # ---------------------------Step 5. Create infer request--------------------------------------------------------------
    # load_network() method of the IECore class with a specified number of requests (default 1) returns an ExecutableNetwork
    # instance which stores infer requests. So you already created Infer requests in the previous step.
    # ---------------------------Step 6. Prepare input---------------------------------------------------------------------
    original_image = cv2.imread(args.input)
    image = original_image.copy()
    _, _, h, w = net.input_info[input_blob].input_data.shape
    if image.shape[:-1] != (h, w):
        log.warning(f'Image {args.input} is resized from {image.shape[:-1]} to {(h, w)}')
        image = cv2.resize(image, (w, h))
    # Change data layout from HWC to CHW
    image = image.transpose((2, 0, 1))
    # Add N dimension to transform to NCHW
    image = np.expand_dims(image, axis=0)
    # ---------------------------Step 7. Do inference----------------------------------------------------------------------
    log.info('Starting inference in synchronous mode')
    res = exec_net.infer(inputs={input_blob: image})
#    print(res)
    # ---------------------------Step 8. Process output--------------------------------------------------------------------
    # Generate a label list
#    if args.labels:
#        with open(args.labels, 'r') as f:
#            labels = [line.split(',')[0].strip() for line in f]
    res = res[out_blob]
    print(res[0,0])
#    print(res)
    # Change a shape of a numpy.ndarray with results to get another one with one dimension
    probs = res.reshape(num_of_classes)
    # Get an array of args.number_top class IDs in descending order of probability
    top_n_idexes = np.argsort(probs)[-args.number_top :][::-1]
    print(top_n_idexes)
#    header = 'classid probability'
#    header = header + ' label' if args.labels else header
#    log.info(f'Image path: {args.input}')
#    log.info(f'Top {args.number_top} results: ')
#    log.info(header)
#    log.info('-' * len(header))
#    for class_id in top_n_idexes:
#        probability_indent = ' ' * (len('classid') - len(str(class_id)) + 1)
#        label_indent = ' ' * (len('probability') -  if args.labels else ''
#        label = labels[class_id] if args.labels else ''
#        log.info(f'{class_id}{probability_indent}{probs[class_id]:.7f}{label_indent}{label}')
#    log.info('')
#    log.info('This sample is an API example, for any performance measurements please use the dedicated benchmark_app tool\n')
#    return 0
if __name__ == '__main__':
    sys.exit(main())
edited_hello_classification_2022
# Copyright (C) 2018-2022 Intel Corporation
import sys
import cv2
import numpy as np
from openvino.preprocess import PrePostProcessor, ResizeAlgorithm
from openvino.runtime import Core, Layout, Type
def main():
    # Parsing and validation of input arguments
    if len(sys.argv) != 4:
        log.info(f'Usage: {sys.argv[0]} <path_to_model> <path_to_image> <device_name>')
        return 1
    model_path = sys.argv[1]
    image_path = sys.argv[2]
    device_name = sys.argv[3]
# --------------------------- Step 1. Initialize OpenVINO Runtime Core ------------------------------------------------
    log.info('Creating OpenVINO Runtime Core')
    core = Core()
# --------------------------- Step 2. Read a model --------------------------------------------------------------------
    log.info(f'Reading the model: {model_path}')
    model = core.read_model(model_path)
    if len(model.inputs) != 1:
        return -1
    if len(model.outputs) != 1:
        return -1
# --------------------------- Step 3. Set up input --------------------------------------------------------------------
    # Read input image
    image = cv2.imread(image_path)
    # Add N dimension
    input_tensor = np.expand_dims(image, 0)
# --------------------------- Step 4. Apply preprocessing -------------------------------------------------------------
    ppp = PrePostProcessor(model)
    _, h, w, _ = input_tensor.shape
    # 1) Set input tensor information:
    # - input() provides information about a single model input
    # - reuse precision and shape from already available `input_tensor`
    # - layout of data is 'NHWC'
    ppp.input().tensor() \
        .set_shape(input_tensor.shape) \
        .set_element_type(Type.u8) \
        .set_layout(Layout('NHWC'))  # noqa: ECE001, N400
    # 2) Adding explicit preprocessing steps:
    # - apply linear resize from tensor spatial dims to model spatial dims
    ppp.input().preprocess().resize(ResizeAlgorithm.RESIZE_LINEAR)
    # 3) Here we suppose model has 'NCHW' layout for input
    ppp.input().model().set_layout(Layout('NCHW'))
    # 4) Set output tensor information:
    # - precision of tensor is supposed to be 'f32'
    ppp.output().tensor().set_element_type(Type.f32)
    # 5) Apply preprocessing modifying the original 'model'
    model = ppp.build()
# --------------------------- Step 5. Loading model to the device -----------------------------------------------------
    compiled_model = core.compile_model(model, device_name)
# --------------------------- Step 6. Create infer request and do inference synchronously -----------------------------
    results = compiled_model.infer_new_request({0: input_tensor})
#    print(results)
# --------------------------- Step 7. Process output ------------------------------------------------------------------
    predictions = next(iter(results.values()))
    #print(predictions)
#    print(dir(predictions))
#    print(type(predictions))
#    print(predictions.shape)
    print(predictions[0,0])
    probs = predictions.reshape(-1)
    # Get an array of 10 class IDs in descending order of probability
    top_10 = np.argsort(probs)[-10:][::-1]
    print(top_10)
#    header = 'class_id probability'
#    log.info(f'Image path: {image_path}')
#    log.info('Top 10 results: ')
#    log.info(header)
#    for class_id in top_10:
#        probability_indent = ' ' * (len('class_id') - len(str(class_id)) + 1)
#        log.info(f'{class_id}{probability_indent}{probs[class_id]:.7f}')
#    log.info('')
#    return 0
    sys.exit(main())
Wan
North-man
Hi Wan,
Thank you for your answer, I understand.
My environment is Windows 10 and C++, so I tried with the following C++ sample.
■OpenVINO 2021.4
C:\Program Files (x86)\Intel\openvino_2021.4.752\inference_engine\samples\cpp\classification_sample_async
■OpenVINO 2022.3.
C:\Program Files (x86)\Intel\openvino_2022.3.0\samples\cpp\classification_sample_async
The detailed output values are different from the first post, but the trend is the same.
(I think the difference in the output values from my first post is due to problems such as preprocessing, the order of the input images, color order, ...)
Result when using OpenVINO™ toolkit 2021.4   : -1.93943
Result when using OpenVINO™ toolkit 2021.4   : -54.9816
Result when using OpenVINO™ toolkit 2022.3   : -54.9816
A reference image is attached below.
Added display of first three output values.
■OpenVINO 2021.4 and Mode1
■OpenVINO 2022.3 and Mode1
■OpenVINO 2021.4 and Mode2
■OpenVINO 2022.3.0 and Mode2
I may not be able to meet your request, but if you have any other requests, please let me know.
North-man
Wan_Intel
Hi North-man,
Let us check with our next level and we'll update you at the earliest.
Wan
Wan_Intel
Hi North-man,
We've got feedback from our next level. May I know if you installed OpenVINO™ toolkit on Windows from Installer? Or do you build OpenVINO™ toolkit from GitHub?
On another note, could you please share your hardware details and Operating System with us? This information was being requested by our next level to further troubleshoot the issues.
Wan
North-man
Hi Wan,
thank you for your research.
I installed OpenVINO from the installer.
https://www.intel.com/content/www/us/en/developer/tools/openvino-toolkit/download.html
Both "Development Tools" and "Runtime" will download the same installer.
  • w_openvino_toolkit_p_2021.4.752_online.exe
When I ran the installer, OpenVINO was installed below.
  • C:\Program Files (x86)\Intel\openvino_2021.4.752
And I Used the below files.
  • deployment_tools\inference_engine\bin\intel64\Release
  • deployment_tools\inference_engine\lib\intel64\Release
  • deployment_tools\inference_engine\include
  • deployment_tools\inference_engine\samples\cpp
I chose "Runtime"  and zip file on the next page.
Then I unpacked the zip file and got the following,
  • runtime\bin\intel64\Release
  • runtime\lib\intel64\Release
  • runtime\include
  • samples\cpp
My OS and Hardware (CPU) are below,
  • OS : Windows 10 Enterprise (Version 21H2)
  • CPU : Intel(R) Xeon(R) W-2145 CPU @ 3.70GHz 3.70 GHz
Do you have enough information? Please let me know if I'm missing.
North-man
Wan_Intel
Hi North-man,
Let me share the information with next level and we'll update progress here as soon as possible. Thanks.
Wan
Wan_Intel
Hi Northman,
We've received feedback from our next level.
The difference between results from OpenVINO™ Toolkit 2021.4 and OpenVINO™ Toolkit 2022.3 is that for OpenVINO™ Toolkit 2021.4, low precision transformations were not executed because the input intervals are not constant.
This was fixed some time ago in the ONNX frontend https://github.com/openvinotoolkit/openvino/blob/master/src/frontends/onnx/frontend/src/op/quantize_linear.cpp#L91-L103.
Furthermore, the results from the quantized model are so different than the results from the non-quantized model. We are still checking if it is expected behavior or not.
When low precision transformations are executed (like it's the case for OpenVINO™ Toolkit 2022.3) it can affect precision since the layers potentially can be executed with u8/i8 data types.
On another note, the probability results look suspicious. They should be within [0, 1] range but we get values like 188.1398773, etc. Is the model missing Softmax or something alike?
If you, for example, run hello_classification with alexnet from the open model zoo, the results look like follows:
[ INFO ] Top 10 results:
[ INFO ] class_id probability
[ INFO ] --------------------
[ INFO ] 340 0.9999918
[ INFO ] 292 0.0000066
[ INFO ] 282 0.0000012
[ INFO ] 293 0.0000004
[ INFO ] 288 0.0000001
[ INFO ] 83 0.0000000
[ INFO ] 290 0.0000000
[ INFO ] 102 0.0000000
[ INFO ] 63 0.0000000
[ INFO ] 287 0.0000000
Where 340 is the class id for zebra.
Wan
North-man
Hi Wan,
thank you for your research and feedback.
>This was fixed some time ago in the ONNX frontend ...
I will also check the ONNX frontend.
It's hard to judge, but...
I would like to know which of the following.
  • 2021.4 was wrong (bug) and got it right in 2022.3
  • 2021.4 is not wrong, but 2022.3 is better
Yes, my model does not have softmax.
If there is no softmax, it will not be 0-1 numerically, but there is no problem with the performance of classification.
If necessary, we also prepare a model with softmax added.
North-man
Wan_Intel
Hi North-man,
You may share the model which contains softmax to the following email to further investigate the issue.
Wan
Wan_Intel
Hi North-man,
Thanks for your question.
Please submit a new question when additional information is needed as this thread will no longer be monitored.
Wan
North-man
Hi Wan,
Sorry for late reply.
@Wan_Intel wrote:
Hi North-man,
Wan
I will prepare a model with softmax added,  is it okay if I reply to your address?
North-man
Wan_Intel
Hi North-man.
Yes, you can share the model to the email address above.
We can continue our discussion here.
Wan
North-man
Hi, Wan.
I understand.
I will email you when it is ready.
Please wait a little more.
Thank you.
North-man
Wan_Intel
Hi North-man,
Thanks for sharing your information.
We've received your model and we'll further investigate the issue and update you as soon as possible.
Wan
