6592 Discussions
[ ERROR ] AssertionFailed: inputs.size() == 1
MIfil
Running into this error when trying to build the Object Detection Sample. Can someone help me solve this error?
pi@raspberrypi:~/Downloads/build $ ./armv7l/Release/object_detection_sample_ssd -m face-detection-adas-0001.xml -d MYRIAD -i /home/pi/Documents/download.jpeg
[ INFO ] InferenceEngine:
API version ............ 1.4
Build .................. 19154
Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]   /home/pi/Documents/download.jpeg
[ INFO ] Loading plugin
API version ............ 1.5
Description ....... myriadPlugin
[ INFO ] Loading network files:
face-detection-adas-0001.bin
[ INFO ] Preparing input blobs
[ INFO ] Batch size is 1
[ INFO ] Preparing output blobs
[ INFO ] Loading model to the plugin
Sahira_Intel
Hi MIfil,
A couple questions for you:
  1. What version of OpenVINO are you using? If you're not using the latest version, please upgrade and run this sample again.
  2. Are you getting an Assertion Failure error on every sample you try to build?
  3. Lastly, have you set up your environment variables? initialize environment variables using this command:
source /opt/intel/openvino/bin/setupvars.sh
  • To permanently initialize environment variables each time a new terminal is opened, run
echo "source /opt/intel/openvino/bin/setupvars.sh" >> ~/.bashrc
Sahira
