6592 Discussions
How do I run the NCS2 with the Pedestrian Tracker Demo?
RVall10
When I try to run with the NCS2 I get this error:
API Version .........1.5
Build ......................19154
Description ...myriadPlugin
[ERROR] [NOT FOUND] DYN_BATCH_ENABLED key does not exist
NCS2 runs fine on the Interactive Face Detection Demo.
Sahira_Intel
Hi Ron,
A couple questions for you:
  1. What version of OpenVINO are you using?
  2. Can you provide more information about your system: What OS you're running on, etc.
  3. What model did you use with the Pedestrian Tracker Demo?
  4. What command did you use to convert the model to IR format?
Sahira
RVall10
Hello Sahira,
I am using OpenVINO version R5.0.1 for Windows on a Core i5-7440HQ Dell laptop with 16GB of memory running Win10 ver 1803.
I’m using the models provided with the demo, so I did not convert them. Here are the run commands:
The first run using the GPU works fine. The second using the MYRIAD fails.
pedestrian_tracker_demo -i .\cr_video\poe2O.mp4 -m_det \Intel\computer_vision_sdk_2018.5.456\deployment_tools\intel_models\person-detection-retail-0013\FP32\person-detection-retail-0013.xml -d_det GPU -m_reid \Intel\computer_vision_sdk_2018.5.456\deployment_tools\intel_models\person-reidentification-retail-0031\FP32\person-reidentification-retail-0031.xml -d_reid GPU
InferenceEngine:
       API version ............ 1.4
       Build .................. 19154
[ INFO ] Parsing input parameters
Loading plugin GPU
       API version ............ 1.5
       Description ....... clDNNPlugin
[ INFO ] Execution successful
pedestrian_tracker_demo -i .\cr_video\poe2O.mp4 -m_det \Intel\computer_vision_sdk_2018.5.456\deployment_tools\intel_models\person-detection-retail-0013\FP16\person-detection-retail-0013.xml -d_det MYRIAD -m_reid \Intel\computer_vision_sdk_2018.5.456\deployment_tools\intel_models\person-reidentification-retail-0031\FP32\person-reidentification-retail-0031.xml -d_reid GPU
InferenceEngine:
Loading plugin MYRIAD
       Description ....... myriadPlugin
[ ERROR ] [NOT_FOUND] DYN_BATCH_ENABLED key does not exist
Thank you for your help with this issue.
Ron
Sahira_Intel
Please update to the latest version of OpenVINO: R5.0.1 https://software.intel.com/en-us/openvino-toolkit/choose-download/free-download-windows and try running the sample again.
Sahira
