6575 ディスカッション
[ ERROR ] Can not init Myriad device: NC_ERROR
cgciobo
従業員
1,563件の閲覧回数
I have tried to run into an Ubuntu20 docker container, the demo_security_barrier_camera.sh -d MYRIAD demo example from openvino_2021 and i get this error:
E: [ncAPI] [ 334030] [security_barrie] ncDeviceOpen:1013 Failed to find booted device after boot
When I run it with sudo -E it works, but as a normal user it doesn't.
Does anyone had this issue before? Any idea how to make it run as normal user?
I use --volume /dev:/dev, --network=host and --privileged as options in the docker run command.
Thank you
0 件の賞賛
1 解決策
Syamimi_Intel
モデレーター
1,488件の閲覧回数
Hi Cristian-George Ciobotaru,
Thank you for waiting. This behavior is due to the docker security policy and we cannot sudo by default. I would suggest you run the docker in root privileges, then install sudo.
  1. docker run -it -u 0 --rm openvino/ubuntu20_dev:latest
  2. apt update && apt install sudo
  3. demo_security_barrier_camera.sh
Or else you could try these ways:
docker run -itu root:root --rm --privileged -v /dev:/dev --network=host <image_name>
/bin/bash -c "apt update && apt install sudo && deployment_tools/demo/demo_security_barrier_camera.sh -d MYRIAD -sample-options -no_show"
Syamimi
元の投稿で解決策を見る
4 返答(返信)
Syamimi_Intel
モデレーター
1,533件の閲覧回数
Thank you for reaching out. We like to know more information about your environment.
Are you using Ubuntu 20 in the Virtual Machine ?
If yes, this issues can be resolve by enable a USB 3.0 controller and create USB whitelist filters for the virtual machine. The USB 3.0 feature requires the VirtualBox Extension Pack.
  • Shut down the virtual machine
  • With the virtual machine selected on the VirtualBox Manager:
    • Open Settings -> USB
      • Check “Enable USB Controller”
      • Check “USB 3.0 (xHCI) Controller”
      • Add a new USB filter with Vendor ID: 03e7
        • The other filter fields can be blank.
If no, try run the demo_security_barrier_camera.sh with the root privileges:
Syamimi
cgciobo
従業員
1,491件の閲覧回数
Hi Syamimi,
I am running it into a docker container.
Running with sudo works, but i would like to run it without the need of sudo, as a normal user.
Thank you for your quick answer!
Cristian
Syamimi_Intel
モデレーター
1,489件の閲覧回数
Syamimi
Syamimi_Intel
モデレーター
1,468件の閲覧回数
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Syamimi
返信
