6595 Discussions
[ERROR]OpenVINO Inference Engine ImportError
Li__Gan
My environment is Win10x64 Python37 .
The demo_security_barrier_camera.bat is OK.
And I ve already imported openvino and openvino.tools.But i cant import openvino.inference_engine.
I ve set path:
sys.path.append('C:\\Program Files (x86)\\IntelSWTools\\openvino\\python\\python3.7')
sys.path.append('C:\\Program Files (x86)\\IntelSWTools\\openvino\\python\\python3.7\\openvino')
sys.path.append('C:\\Program Files (x86)\\IntelSWTools\\openvino\\python\\python3.7\\openvino\\inference_engine')
The error code is:
DLL load failed:
File "C:\Program Files (x86)\IntelSWTools\openvino\python\python3.7\openvino\inference_engine\__init__.py", line 1, in <module> from .ie_api import * File "C:\Users\ROG\Desktop\MYNT\model.py", line 19, in <module> from openvino.inference_engine import IENetwork, IEPlugin
Li__Gan
The toolkit is openvino_2019.1.148.
Li__Gan
ToolKit is .openvino_2019.1.148
Shubha_R_Intel
Dear Li, Gan,
Glad to see that you are using the latest and greatest OpenVino 2019R1.1.  You should not have to add these :
If you run bin/setupvars.bat, simply go into your python_samples directory and run one of the samples - for instance the classification_sample. It should work. One of the many things setupvars.bat does is set the PYTHONPATH variable.
I think maybe you forgot to run setupvars.bat (*.sh).
Thanks for using OpenVino !
Shubha
