Error DYN_BATCH_ENABLED running pedestrian_tracker_demo with MYRIAD in Raspberry Pi
Sanchez__Raul
Hi , I tried to run the pedestrian_tracker_demo in Raspberry pi with MYRIAD and I got this error:
$ ./armv7l/Release/pedestrian_tracker_demo
-m_det /home/pi/Documents/intel_models/person-detection-retail-0013/FP16/person-detection-retail-0013.xml
-m_reid /home/pi/Documents/intel_models/person-reidentification-retail-0031/FP16/person-reidentification-retail-0031
-i /home/pi/Downloads/video1.webm
InferenceEngine:
API version ............ 1.4
Build .................. 19154
[ INFO ] Parsing input parameters
Loading plugin MYRIAD
API version ............ 1.5
Description ....... myriadPlugin
[ ERROR ] [NOT_FOUND] DYN_BATCH_ENABLED key does not exist
Chu__James1
I met the same problem.  Please help!  Thank you.
Bhargava__Rachit
Any luck solving this?
Shubha_R_Intel
Dearest everyone,
Can you kindly confirm that you are using the latest Raspberry Pi OpenVino toolkit listed here ?
If indeed you are, then it looks like a bug and I will gladly file it on your behalf. Please confirm that you're using the latest.
Shubha
