6574 Discussions
Error during Openvino inference of Mask R-CNN Inception ResNet V2 1024x1024
Vishnuj
I tried to run inference of Mask R-CNN Inception ResNet V2 1024x1024 from Tensorflow2 Model Zoo. I am using the following command to convert the tensorflow model.
mo --saved_model_dir "mask_rcnn_inception_resnet_v2_1024x1024_coco17_gpu-8/saved_model" --transformations_config "/root/sharedfolder/dent_damage_det/mask_rcnn_support_api_v2.0.json" --tensorflow_object_detection_api_pipeline_config "mask_rcnn_inception_resnet_v2_1024x1024_coco17_gpu-8/pipeline.config" --output_dir "/root/sharedfolder/dent_damage_det/mrcnn_zoo" --input_shape [1,1024,1024,3]
The model got converted successfully. While running inference on the converted model I am getting this error:
RuntimeError                              Traceback (most recent call last)
<ipython-input-68-f922978d5286> in <module>
      7 request = compiled_model.create_infer_request()
      8 input_image = np.zeros((1, 1024, 1024,3))
----> 9 request.infer(inputs={input_layer.any_name: input_img})
/opt/intel/openvino/python/python3.6/openvino/runtime/ie_api.py in infer(self, inputs)
    108         """
    109         return super().infer(
--> 110             {} if inputs is None else normalize_inputs(inputs, get_input_types(self))
    111         )
    112
RuntimeError: Proposal operation image info input must have positive image height and width.
Code to run inference:
ie_core = Core()
model = ie_core.read_model(model=model_path, weights=model_weights_path)
compiled_model = ie_core.compile_model(model=model, device_name="CPU")
input_layer = next(iter(compiled_model.inputs))
output_layers = list(compiled_model.outputs)
Zulkifli_Intel
Hello Vishnuj
The Python code that you shared appears to be incomplete. You can refer to Inference Pipeline for guidance.
For your information, Intel Open Model Zoo has two mask_rcnn models:
Both of these models can be run with Object Detection Mask R-CNNs Segmentation C++ Demo.
Sincerely,
Zulkifli
Zulkifli_Intel
Hello Vishnuj,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Sincerely,
Zulkifli
