Error " Emotions-Recognition-Retail-0003.xml " Models with raspberry pi 4B + NCS 2
rnd-amg
Hi Team,
i want test this model " emotions-recognition-retail-0003.xml ", but it got error " [ ERROR ] Output item should have 7 as a last dimension "
Please let me know the workaround to avoid the error.
and is there any others demo models emotions-recognition that i can use to test?
rnd
Peh_Intel
Hi Rnd,
You’re getting the error because the Object Detection Sample SSD does not support the emotions-recognition-retail-0003 model.
The emotions-recognition-retail-0003 model is supported by the G-API Interactive Face Detection Demo and Interactive Face Detection C++ Demo.
Peh
rnd-amg
Hi @Peh_Intel ,
Thanks for the reply
i cant find path " cpp/models.lst " or " cpp_gapi/models.lst " in my "  ~/open_model_zoo/demos/interactive_face_detection_demo/ "
where i can find the path or i must donwload it first?
rnd
Peh_Intel
Hi Rnd,
I observed that you’re using Inference Engine 2021.4.2 from your first screenshot. Hence, it is recommended to use the same version as the Open Model Zoo. There are the cpp and cpp_gapi files in Open Model Zoo 2021.4.2.
Peh
rnd-amg
Hi @Peh_Intel ,
already download " https://github.com/openvinotoolkit/open_model_zoo/tree/2021.4.2/demos/interactive_face_detection_demo "
but i got error when ruh this command " ./object_detection_demo -d MYRIAD -m /home/pi/Downloads/open_model_zoo-2021.4.2/tools/downloader/intel/emotions-recognition-retail-0003/FP16/emotions-recognition-retail-0003.xml -at ssd -i 0 "
Regard,
rnd
Peh_Intel
Hi Rnd,
The -m <model> is required to point to the path of an .xml file with a trained Face Detection model.
Hence, taking face-detection-adas-0001 model as the example of Face Detection model, the proper command should be:
./object_detection_demo -d MYRIAD -m face-detection-adas-0001.xml -d MYRIAD -m_em /home/pi/Downloads/open_model_zoo-2021.4.2/tools/downloader/intel/emotions-recognition-retail-0003/FP16/emotions-recognition-retail-0003.xml -d_em MYRIAD -at ssd -i 0
Peh
rnd-amg
Hi @Peh_Intel
got error when run this command "
./object_detection_demo -d MYRIAD -m face-detection-adas-0001.xml -d MYRIAD -m_em /home/pi/Downloads/open_model_zoo-2021.4.2/tools/downloader/intel/emotions-recognition-retail-0003/FP16/emotions-recognition-retail-0003.xml -d_em MYRIAD -at ssd -i 0 "
rnd
Peh_Intel
Hi Rnd,
I am sorry that I overlooked you are running the object detection demo. As I mentioned previously, the emotions-recognition-retail-0003 model is supported by the G-API Interactive Face Detection Demo and Interactive Face Detection C++ Demo.
1.      Pull the Open Models Zoo repository:
git clone -b 2021.4.2 https://github.com/openvinotoolkit/open_model_zoo.git
2.      Execute the demo application:
cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_CXX_FLAGS="-march=armv7-a" <clone_dir>/open_model_zoo/demos
make -j2 interactive_face_detection_demo
3.      Run the Interactive Face Detection C++ Demo:
./ interactive_face_detection_demo
Peh
Peh_Intel
Hi Rnd,
This thread will no longer be monitored since we have provided solutions. If you need any additional information from Intel, please submit a new question.
Peh
