Error raised in OpenVINO Demo Test
Jiang__HJ
Hello!
I'm new to OpenVINO and I need your help. I'm trying to run the demo (demo_squeezenet_download_convert_run.bat) after the installation and path setting. However, I came across some problems when the code ran into -> Build Inference Engine samples using MS Visual Studio (MSBuild.exe).
Here's my hardware information and OS:
CPU: Intel(R) Xeno(R) W-2133 CPU
OS: Windows 10 x64
I've followed the steps in the installation guide and installed:
1 openvino_toolkit_p_2019.3.334
2 visual studio 2015
3 Cmake  3.9.3
4 Python 3.6.5
Please check the attachment for the error, I have just copy the initial few parts of the error raised in ext_base.hpp for the list of error is quite long and all happened in the same solution (ie_cpu_extension\ie_cpu_extension.vcxproj). It seems that everything just crashed when the codes ran into ext_base.hpp. By the way, I have tried to change the version of Openvino and Python but all got the same error.
I will very appreciate it if you can give me any suggestion on that. Thank you in advance.
Sincerely,
HJ
HemanthKum_G_Intel
Hi HJ,
When you installed VS2015 did you select the c++ package? If you just install VS2015 without customizing your install to select the c++ package then by default it comes without it and you can get such error.
Refer to this document - https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_windows.html - Step 2. Install the dependencies:
Microsoft Visual Studio* with C++ 2019, 2017, or 2015 with MSBuild.
If this doesn't fix, try to download and install Visual C++ Redistributable for Visual Studio 2015.
Reboot the system to get the environment variables set properly.
