Error when i use NCS2: ncDeviceOpen:672 Failed to find suitable device, rc: X_LINK_DEVICE_NOT_FOUND
redans__redans
I recently bought Neural Compute Stick 2, Powered by Intel movidius myriad x vpu, NCS 2. I follwed those steps : https://software.intel.com/en-us/articles/get-started-with-neural-compute-stick and when I tried to test my install. (step 4), I recevied next error:
[ INFO ] Loading model to the plugin
E: [ncAPI] [ 231949] ncDeviceOpen:672 Failed to find suitable device, rc: X_LINK_DEVICE_NOT_FOUND
[ ERROR ] Can not init USB device: NC_ERROR
Error on or near line 241; exiting with status 1
I used this distribution of Ubuntu, in VMware Workstation, it is a VM guest, in a Win10 host.
Distributor ID: Ubuntu
Description: Ubuntu 16.04.6 LTS
Release: 16.04
Codename: xenial
OpenVINO toolkit works great, no error. I've tried this tutorial https://github.com/incluit/OpenVino-For-SmartCity and all examples works on CPU and now I want to execute them with MYRIAD . Do you have any suggestions?
Sahira_Intel
Hi Redans,
Did you configure the USB driver for the NCS?
Run the following commands and try again:
source ~/intel/openvino/bin/setupvars.sh
cd ~/intel/openvino/install_dependencies
./install_NCS_udev_rules.sh
Please let me know if you have any further questions.
Sahira
meng__wu
Hi,  I also recevied next error:
I used this distribution of Ubuntu, 16.04.6 LTS. and I also run the following commands:
1.source ~/intel/openvino/bin/setupvars.sh
2.cd ~/intel/openvino/install_dependencies
3./install_NCS_udev_rules.sh
Do you solved it? Thank you!
Meng
redans__redans
Thanks for your advice! It's works!
meng__wu
I used this distribution of Ubuntu, 16.04.6 LTS. and I also run the following commands :
Do you solve it? Thanks!
Meng
meng__wu
Hi Sahira,
1.source ~/intel/openvino/bin/setupvars.sh 2. cd ~/intel/openvino/install_dependencies 3. ./install_NCS_udev_rules.sh
but I still recieve this error: ncDeviceOpen:672 Failed to find suitable device, rc: X_LINK_DEVICE_NOT_FOUND.
I used this distribution of Ubuntu 16.04.6 LTS.  Besides, I found the inference speed of using cpu(i5-8500)  is faster than NEURAL Compute stick 2.  Why this? Can you give me some advice. Thank you!
Meng
meng__wu
Hi Sahira,
Meng
Shubha_R_Intel
Dear meng, wu,
Inference speed of a CPU being faster than VPU is not so unusual. It's a power/performance trade off. VPUs give great performance at lower power consumption.
For your NCS2 issues, please follow these guides:
OpenVino Linux Install
Additional NCS2 steps
Also please kindly make sure you are on the latest OpenVino version, which is 2019R1.1.
Shubha
redans__redans
Yes, I solved it! It's important to execute following commands
and then to plug in your NCS2 stick.
Shubha_R_Intel
Dear redans, redans,
Excellent news ! I really appreciate your sharing your victory and feedback with the OpenVino community.
March On with OpenVino !
Shubha
tbarr7
Hello
I have a same X_LINK_DEVICE_NOT_FOUND problème only with security_barrier_demo sample, another samples running without problem.
and i have use there command without result :
and retour message :
Update udev rules so that the toolkit can communicate with your neural compute stick
[install_NCS_udev_rules.sh] udev rules installed
The problem only appears when loading the 2nd and 3rd models, the 1st model load correctly.
you can find in attach the screen copy
my config : Raspberry pi3B, Raspian Buster, NCS2
Thank you very much for your help
Thierry
tbarr7
Hello
I have a same problem  ncDeviceOpen:672 Failed to find suitable device, rc: X_LINK_DEVICE_NOT_FOUND in 2 differents CPU (Raspberry PIn 3B and ODROID XU4 and NC2) you can find in attach a screen copy.
The problem only occurs if I have more than 1 model to load.
There is no error with examples that have only 1 model.
the problem only appears with the version "l_openvino_toolkit_raspbi_p_2019.1.144.tgz" NOT with "l_openvino_toolkit_raspbi_p_2019.1.094.tgz" version.
After some research, if I replace the directory "/opt/intel/openvino/deployment_tools/inference_engine/lib/armv7l" by the one of the "l_openvino_toolkit_raspbi_p_2019.1.094.tgz" version, the problem disappears.
Do you have any idea what the problem is?
Thanks Thierry
Zhang__JIaYu
Hello,when I insert 2 ncs2 at the same time ,the code ddidn't work.
It occurs
```E: [ncAPI] [         0] ncDeviceOpen:672        Failed to find suitable device, rc: X_LINK_DEVICE_NOT_FOUND
  File "async_api_multi-threads_multi-requests.py", line 131, in <module>
    sys.exit(main() or 0)
  File "async_api_multi-threads_multi-requests.py", line 111, in main
    exec_net = plugin.load(network=net, num_requests=request_number*2)
  File "ie_api.pyx", line 395, in openvino.inference_engine.ie_api.IEPlugin.load
  File "ie_api.pyx", line 406, in openvino.inference_engine.ie_api.IEPlugin.load
RuntimeError: Can not init USB device: NC_ERROR
