Error when trying demo
sky_lu
Hi, I have installed Openvino recently and when I try to run the demo_benchmark_app.bat to test my installation, it keeps telling me the error like below.
C:\Program Files (x86)\IntelSWTools\openvino_2020.4.318\deployment_tools\demo>conda activate tf_gpu
(tf_gpu) C:\Program Files (x86)\IntelSWTools\openvino_2020.4.318\deployment_tools\demo>demo_benchmark_app.bat -d cpu
target = cpu
target_precision = FP16
'where' 不是内部或外部命令,也不是可运行的程序
或批处理文件。
Warning: libmmd.dll couldn't be found in %PATH%. Please check if the redistributable package for Intel(R) C++ Compiler is installed and the library path is added to the PATH environment variable. System reboot can be required to update the system environment.
[setupvars.bat] OpenVINO environment initialized
INTEL_OPENVINO_DIR is set to C:\Program Files (x86)\IntelSWTools\openvino_2020.4.318
ECHO 处于关闭状态。
Requirement already satisfied: pyyaml in c:\users\lenovo\appdata\roaming\python\python36\site-packages (from -r C:\Program Files (x86)\IntelSWTools\openvino_2020.4.318\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 1)) (5.3.1)
Requirement already satisfied: requests in c:\users\lenovo\appdata\roaming\python\python36\site-packages (from -r C:\Program Files (x86)\IntelSWTools\openvino_2020.4.318\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2.18.4)
Requirement already satisfied: idna<2.7,>=2.5 in c:\users\lenovo\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino_2020.4.318\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2.6)
Requirement already satisfied: urllib3<1.23,>=1.21.1 in c:\users\lenovo\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino_2020.4.318\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (1.22)
Requirement already satisfied: certifi>=2017.4.17 in f:\anaconda\envs\tf_gpu\lib\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino_2020.4.318\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2020.6.20)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in c:\users\lenovo\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino_2020.4.318\deployment_tools\demo\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (3.0.4)
Download public squeezenet1.1 model
python "C:\Program Files (x86)\IntelSWTools\openvino_2020.4.318\deployment_tools\open_model_zoo\tools\downloader\downloader.py" --name "squeezenet1.1" --output_dir "C:\Users\lenovo\Documents\Intel\OpenVINO\openvino_models\models" --cache_dir "C:\Users\lenovo\Documents\Intel\OpenVINO\openvino_models\cache"
################|| Downloading models ||################
========== Retrieving C:\Users\lenovo\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.prototxt from the cache
========== Retrieving C:\Users\lenovo\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.caffemodel from the cache
################|| Post-processing ||################
========== Replacing text in C:\Users\lenovo\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.prototxt
squeezenet1.1 model downloading completed
'timeout' 不是内部或外部命令,也不是可运行的程序
或批处理文件。
Target folder C:\Users\lenovo\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16 already exists. Skipping IR generation with Model Optimizer.
If you want to convert a model again, remove the entire C:\Users\lenovo\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16 folder.
或批处理文件。
###############|| Generate VS solution for Inference Engine samples using cmake ||###############
或批处理文件。
"vswhere tool is not found"
Creating Visual Studio 14 2015 x64 files in C:\Users\lenovo\Documents\Intel\OpenVINO\inference_engine_samples_build...
-- Selecting Windows SDK version 10.0.14393.0 to target Windows 10.0.18363.
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
CMake Error at CMakeLists.txt:7 (project):
No CMAKE_C_COMPILER could be found.
No CMAKE_CXX_COMPILER could be found.
-- Configuring incomplete, errors occurred!
See also "C:/Users/lenovo/Documents/Intel/OpenVINO/inference_engine_samples_build/CMakeFiles/CMakeOutput.log".
See also "C:/Users/lenovo/Documents/Intel/OpenVINO/inference_engine_samples_build/CMakeFiles/CMakeError.log".
Error
I installed Visual Studio 2015, python 3.6.4 and I run the order in a new enviornment in Anaconda
Iffa_Intel
Greetings,
Please help to ensure that you run the setupvars everytime you open a new terminal/command prompt.
cd C:\Program Files (x86)\IntelSWTools\openvino\bin\
run setupvars.bat
you can do the same in anaconda, navigate to this folder & run it.
Sincerely,
Iffa
sky_lu
(tf_gpu) C:\Program Files (x86)\IntelSWTools\openvino\bin>setupvars.bat
或批处理文件。
target = cpu
或批处理文件。
ECHO 处于关闭状态。
或批处理文件。
或批处理文件。
或批处理文件。
'cmake' 不是内部或外部命令,也不是可运行的程序
或批处理文件。
Error
I have re-install the VS2015 this time and it still doesn't work
Iffa_Intel
Greetings,
I recommend you to follow this latest official documentation: https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_windows.html
You need to get these pre-requisite correct:
  1. Microsoft Visual Studio* with C++ 2019 or 2017 with MSBuild (I recommend 2019,tick on C++/GCC if the option pops up during installation)
  2. CMake 2.8.12 or higher 64-bit (ensure to add this to your system path)
  3. Python 3.5 - 3.7 64-bit ( Irecommend to go for python 3.6)
  4. Intel® Distribution of OpenVINO™ toolkit core components (2020.4 is the latest)
Hope this helps!.
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question
Sincerely,
Iffa
