- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hi
I'm running two ncs in raspberry pie.
Until one hour ago I was testing 2 ncs well.
But the second ncs just before is not open.
What causes it?
Traceback (most recent call last):
File "image-classifier.py", line 171, in
main()
File "image-classifier.py", line 118, in main
device = open_ncs_device()
File "image-classifier.py", line 38, in open_ncs_device
device.OpenDevice()
File "/usr/local/lib/python3.5/dist-packages/mvnc/mvncapi.py", line 147, in OpenDevice
raise Exception(Status(status))
Exception: mvncStatus.ERROR
Two devices are displayed.
Look for enumerated NCS device(s); quit program if none found.
devices = mvnc.EnumerateDevices()
if len( devices ) == 0:
print( "No devices found" )
quit()
print(str(len(devices)))
result = 2
This is lsusb -t result
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
|__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
|__ Port 2: Dev 4, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 10, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 4: Dev 23, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 3: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 5, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 4: Dev 7, If 1, Class=Video, Driver=uvcvideo, 480M
|__ Port 4: Dev 7, If 2, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 4: Dev 7, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 4: Dev 7, If 3, Class=Audio, Driver=snd-usb-audio, 480M
lcs linked ust hub.
I need your help thank you.
Link copiado
2 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
The same symptom occurred when rebooting.
But after about 1 hour, I tried again and it was working normally.
I do not know what the cause is……
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
@sulki.kim Please make sure you are using a powered USB hub when using multiple NCS devices on the Raspberry Pi. Give this a try and let me know if it solves your issue. Thanks.
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
