6605 Discussions
Parallel processing of multiple Movidius NCSs based on c/c++
I’d like to chain several Movidius NCSs together to increase throughput based on c/c++. I've already checked the followings:
https://ncsforum.movidius.com/discussion/241/performance-scaling-with-multiple-sticks
https://ncsforum.movidius.com/discussion/112/chaining-movidius-sticks#latest
https://github.com/duangenquan/YoloV2NCS
The ObjectWrapper.py and Main.py in the YoloV2NCS github (the last link) is actually what I have found, but it is based on python, rather than c/c++. Is there an c/c++ example source code showing parallel processing of multiple NCSs?
@JadeShin At the moment, there isn't a C++ example on the NCAPPZOO that shows how to do this. If you want to, you can look at the video_objects_threaded python example and extrapolate to C++.
@Tome_at_Intel Thank you for your reply. I have one more question.
I have checked movidius NCS supports TensorFlow framework. Then, does movidius NCS also supports TensorFlow Lite ?
