Hello, I'm trying to convert a .pb Tensorflow (1.14v) with @Intel® Distribution of OpenVINO™ toolkit
but I'm keep getting this error with input shape:
[ ERROR ] Cannot infer shapes or values for node "replica_0_1/lambda_7/Slice".
[ ERROR ] Output shape: [ 0 768 512 3] of node "replica_0_1/lambda_7/Slice" contains non-positive values
[ ERROR ]
[ ERROR ] It can happen due to bug in custom shape infer function <function Slice.infer at 0x000001F24BFBB3A0>.
[ ERROR ] Or because the node inputs have incorrect values/shapes.
[ ERROR ] Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
This is the command I'm using "python mo.py --input_model <Input_Model> --input inputs_mask,inputs_img --input_shape [1,768,512,3],[1,768,512,3]"
I also tried [1,3, 768,512],[1,3,768,512] and tried the -b 1 solution, I got the same error with all of them.
Only when I tried -b 1 I got the a different shape in the error above
[ ERROR ] Cannot infer shapes or values for node "replica_2_1/lambda_11/Slice".
[ ERROR ] Output shape: [ 0 512 768 3] of node "replica_2_1/lambda_11/Slice" contains non-positive values
[ ERROR ]
[ ERROR ] It can happen due to bug in custom shape infer function <function Slice.infer at 0x000002577C4A13A0>.
Hi HA14,
Thank you for reaching out to us. If possible, could you share additional information regarding the Tensorflow model:
- Is it a custom model or a public model?
- If it is a custom model, please specify which topology is applied to the model.
- If it is a public model, please specify which model.
If it is a custom model, please verify the model layers/operations are supported by the OpenVINO toolkit. To see the layers supported by the Tensorflow framework, please refer to the following link:
Adli
Hi HA14,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Adli
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
