6575 Discussions
Export gaze estimation demo results to a csv file and/or print them to the command prompt?
Morgan1
Hello all,
I'm running the gaze estimation demo, however I'm trying to print the head position angles/export them to a .csv file. I've added some code to the file "face_inference_results.cpp" to print to command prompt and export it to a .csv file, however it's not printing/exporting anything. I've tried adding some test print statements as well and nothing is being printed from face_inference_results.cpp.
Is there a different file I should put the print and fstream statements in?
Thank you for any help!
Morgan
Vladimir_Dudnik
@Morgan1  according to the demo description you may try to use -r option to print raw detection results to console window
    -r                       Optional. Output inference results as raw values.
Vladimir_Dudnik
Wan_Intel
Hi Morgan Belcher,
This thread will no longer be monitored since this issue has been resolved.
If you need any additional information from Intel, please submit a new question.
Wan
