FP16 model unable to run in OpenVINO
DarkHorse
My customer has train their AI model using PyTorch framework using Intel Sonoma Creek and they want to run the AI Inference on a VPU accelerator card.
They managed to convert their model from:
PyTorch -> ONNX -> FP16 IR Format
I have confirmed their FP16 model on my OpenVINO 2021 and showing similar error messages:
[ INFO ] Parsing input parameters
[ INFO ] Reading input
[ INFO ] Loading Inference Engine
[ INFO ] Device info:
[ INFO ] CPU
MKLDNNPlugin version ......... 2021.4
Build ........... 0
Loading network files
[ ERROR ] Unknown model format! Cannot find reader for model format: xml and read the model: model_barehand.xml. Please check that reader library exists in your PATH.
Customer have no issue running FP32 model in OpenVINO 2022 on CPU.
Customer also tried FP16 model person-detection retail 002 from intel it working ok
Can someone have a look into this?
Peh_Intel
Hi DarkHorse,
For your information, in the latest version of OpenVINO™, the error message has changed... earlier it explicitly reported that the found IR-version is not supported... now it fails with "Unknown model format! Cannot find reader for model format".
In short words, OpenVINO™ 2022 is able to load IRv10 (converted by Model Optimizer 2021.4) and IRv11 (converted by Model Optimizer 2022.1) into Inference Engine whereas OpenVINO™ 2021.4 is only able to load IRv10 and will produce the above error if loading IRv11.
Peh
DarkHorse
Hello Peh,
My customer is seeing the same error messages even he is trying to run the inferencing in OpenVINO 2022?
Attached is the log files... can you have a look?
Wan_Intel
Hi DarkHorse,
Referring to this article, could you please check if both inference_engine_ir_reader.dll and inference_engine.dll are located in the following directory:
<INSTALL_DIR>\deployment_tools\inference_engine\bin\intel64\Release
Wan
Peh_Intel
Hi DarkHorse,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Peh
Farhâd
I see this same problem on the raspberry pi4b.  Please let me know the solution.
