- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
I am trying to write an application to do face recognition with Intel NCS2 stick on Intel i7 PC. I have also installed Openvino toolkit to support for NCS2. So, to do face recognition, i have converted tensorflow facenet(https://github.com/davidsandberg/facenet) models to .bin and .xml using openvino model optimizer script as,
$ python ./mo_tf.py --input_model /mnt/work/RNA_va/face/facenet/Model/20180402-114759.pb --freeze_placeholder_with_value "phase_train->False" --data-type FP16
And here is my test application.
import cv2
net = cv2.dnn.readNet('20180402-114759.bin', 20180402-114759.xml')
net.setPreferableTarget(cv2.dnn.DNN_TARGET_MYRIAD)
vs = VideoStream(src=0).start()
while True:
frame = vs.read()
blob = cv2.dnn.blobFromImage(frame, 0.007843, (300, 300), 127.5)
net.setInput(blob)
detections = net.forward()
And i got the below error when i run this python script,
terminate called after throwing an instance of 'InferenceEngine::details::InferenceEngineException'
what(): Failed to infer shapes for FullyConnected layer (InceptionResnetV1/Bottleneck/MatMul) with error: New shapes [1,64512] make Kernels(), Channels(64512), Output depth(512), Groups(1) not matching weights size: 33030144 vs 917504
Aborted (core dumped)
Can someone help to resolve this issue? Much appreciated. Thanks.
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Dear Kesavaram, Jaiganesh,
Can you first try the OpenVino Multi-Channel Face Detection Demo ?
Info is below:
https://docs.openvinotoolkit.org/latest/_inference_engine_samples_multichannel_demo_README.html
Just pass your IR *.xml for facenet into the -m switch.
Let us know how this works for you. If this works, then please compare your code to the code in this demo.
Shubha
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Shubha,
Here is the output of demo app. Let me know your comments.
$ ./multi-channel-face-detection-demo -m /mnt/work/RNA_va/face/facenet/model_optimized/20180402-114759.xml -d MYRIAD -nc 1
[ INFO ] InferenceEngine:
API version ............ 1.6
Build .................. custom_releases/2019/R1_ebce9728578ef3131f2f282b3fbc3232109c598e
[ INFO ] Parsing input parameters
[ INFO ] Detection model: /mnt/work/RNA_va/face/facenet/model_optimized/20180402-114759.xml
[ INFO ] Detection threshold: 0.5
[ INFO ] Utilizing device: MYRIAD
[ INFO ] Batch size: 1
[ INFO ] Number of infer requests: 5
[ INFO ] Number of input web cams: 1
[ INFO ] Model path: /mnt/work/RNA_va/face/facenet/model_optimized/20180402-114759.xml
[ INFO ] Weights path: /mnt/work/RNA_va/face/facenet/model_optimized/20180402-114759.bin
[ INFO ] Number of input video files: 0
[ INFO ] Duplication multiplayer: 0
[ INFO ] Number of input channels: 1
[ INFO ] Trying to connect 1 web cams ...
To close the application, press 'CTRL+C' or any key with focus on the output window
Segmentation fault (core dumped)
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
And my desktop environment is Ubuntu 18.04 Bionic with OpenVino toolkit l_openvino_toolkit_p_2019.1.133 installed.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Kesavaram,
The Facenet model used to extract facial features(512) from the face. Not used for face detection
Referer below link
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
