Face Recognition with NCS2 and OpenCV
Kesavaram__Jaiganesh
I am trying to write an application to do face recognition with Intel NCS2 stick on Intel i7 PC. I have also installed Openvino toolkit to support for NCS2. So, to do face recognition, i have converted tensorflow facenet(https://github.com/davidsandberg/facenet) models to .bin and .xml using openvino model optimizer script as,
$ python ./mo_tf.py --input_model /mnt/work/RNA_va/face/facenet/Model/20180402-114759.pb --freeze_placeholder_with_value "phase_train->False" --data-type FP16
And here is my test application.
import cv2
net = cv2.dnn.readNet('20180402-114759.bin', 20180402-114759.xml')
net.setPreferableTarget(cv2.dnn.DNN_TARGET_MYRIAD)
vs = VideoStream(src=0).start()
while True:
    frame = vs.read()
    blob = cv2.dnn.blobFromImage(frame, 0.007843, (300, 300), 127.5)
    net.setInput(blob)
    detections = net.forward()
And i got the below error when i run this python script,
terminate called after throwing an instance of 'InferenceEngine::details::InferenceEngineException'
  what():  Failed to infer shapes for FullyConnected layer (InceptionResnetV1/Bottleneck/MatMul) with error: New shapes [1,64512] make Kernels(), Channels(64512), Output depth(512), Groups(1) not matching weights size: 33030144 vs 917504
Aborted (core dumped)
Can someone help to resolve this issue? Much appreciated. Thanks.
Shubha_R_Intel
Dear Kesavaram, Jaiganesh,
Can you first try the OpenVino Multi-Channel Face Detection Demo ?
Info is below:
https://docs.openvinotoolkit.org/latest/_inference_engine_samples_multichannel_demo_README.html
Just pass your IR *.xml for facenet into the -m switch.
Let us know how this works for you. If this works, then please compare your code to the code in this demo.
Shubha
Hi Shubha,
Here is the output of demo app. Let me know your comments.
$ ./multi-channel-face-detection-demo -m /mnt/work/RNA_va/face/facenet/model_optimized/20180402-114759.xml -d MYRIAD -nc 1
[ INFO ] InferenceEngine:
    API version ............ 1.6
    Build .................. custom_releases/2019/R1_ebce9728578ef3131f2f282b3fbc3232109c598e
[ INFO ] Parsing input parameters
[ INFO ]     Detection model:           /mnt/work/RNA_va/face/facenet/model_optimized/20180402-114759.xml
[ INFO ]     Detection threshold:       0.5
[ INFO ]     Utilizing device:          MYRIAD
[ INFO ]     Batch size:                1
[ INFO ]     Number of infer requests:  5
[ INFO ]     Number of input web cams:  1
[ INFO ] Model   path: /mnt/work/RNA_va/face/facenet/model_optimized/20180402-114759.xml
[ INFO ] Weights path: /mnt/work/RNA_va/face/facenet/model_optimized/20180402-114759.bin
[ INFO ]     Number of input video files: 0
[ INFO ]     Duplication multiplayer:     0
[ INFO ]     Number of input channels:    1
[ INFO ] Trying to connect 1 web cams ...
To close the application, press 'CTRL+C' or any key with focus on the output window
Segmentation fault (core dumped)
And my desktop environment is Ubuntu 18.04 Bionic with OpenVino toolkit l_openvino_toolkit_p_2019.1.133 installed.
m__akshaya
Hi Kesavaram,
The Facenet model used to extract facial features(512) from the face. Not used for face detection
Referer below link
https://github.com/MekkaSiekka/Face-Recognition-with-OpenVino-Toolkit/blob/master/local_recognizer/main.cpp
