Failed to Convert ONNX model to IR using Model Optimizer
Villasoto__Alexander
I am trying to convert my onnx model using OpenVINO model optimizer. ONNX conversion from PyTorch is successful but when I try to convert onnx to OpenVINO it returns Unexpected exception happened during extracting attributes for node 175.It is not just node 175. whenever I try to rerun the mo, it returns a different error node. Tried to enable log_level DEBUG but it is not helpful. Can someone help me?
ONNX specific parameters:
Model Optimizer version:     2020.1.0-61-gd349c3ba4a
Alex
Sahira_Intel
Hi Alexander,
I will have to look at your model. Can you please attach it here? I can also PM you if you would rather share your model privately.
Please also send the Model Optimizer command you used.
Sahira
