GraphML File will not be loaded
Ana
I was trying to load the census-transform.graphml document in order to see how the application works. But I get the following error -
Error encountered while parsing GraphML Document (census_transform.graphml)
It is the same with other sample applications as well.
Also, when I run the runvad.sh script, the following lines are displayed -
Could not parse application stylesheet
QObject::connect: No such slot FGDFramework::uc_handle_clear_highlights()
QObject::connect: No such signal FGDGraphScene::items_selected(QList<QGraphicsItem *>&)
[ INFO ] OpenCL build options: -DWORK_ITEM_XSIZE=4 -DWORK_ITEM_YSIZE=1
[ INFO ] OpenCL build options: -DWORK_ITEM_XSIZE=1 -DWORK_ITEM_YSIZE=1
Please let me know if these lines have got anything to do with the GraphML not loading?
Thanks and Regards
Anna_B_Intel
Hi Ana,
What OS do you use? Errors of GraphML parsing usually occurs because of some dependencies and proper driver absence. Did you do all prerequisite steps described here ?
Best wishes,
Anna
