I was trying to load the census-transform.graphml document in order to see how the application works. But I get the following error -
Error encountered while parsing GraphML Document (census_transform.graphml)
GraphML File will not be loaded
It is the same with other sample applications as well.
Also, when I run the runvad.sh script, the following lines are displayed -
Could not parse application stylesheet
QObject::connect: No such slot FGDFramework::uc_handle_clear_highlights()
QObject::connect: No such signal FGDGraphScene::items_selected(QList<QGraphicsItem *>&)
[ INFO ] OpenCL build options: -DWORK_ITEM_XSIZE=4 -DWORK_ITEM_YSIZE=1
[ INFO ] OpenCL build options: -DWORK_ITEM_XSIZE=1 -DWORK_ITEM_YSIZE=1
Please let me know if these lines have got anything to do with the GraphML not loading?
Thanks and Regards
Hi Ana,
What OS do you use? Errors of GraphML parsing usually occurs because of some dependencies and proper driver absence. Did you do all prerequisite steps described here ?
Best wishes,
Anna
