6605 Discussions
Hi! When I updated to OpenVino 2020, my opencv updated as well. The downside is that I am not able to use the TrackerCSRT_create() module anymore, despite that the OpenCV 4.2.0 documentation specified the existence of such module. Is this a bug? Thanks
ECruz8
David_C_Intel
Hi ECruz8,
Thanks for reaching out.
Could you please provide us more details about your issue?
  • Which OS are you using?
  • Steps to reproduce your issue.
  • The error shown.
David C.
A Contingent Worker at Intel
ECruz8
Hi David
I am using both 'Ubuntu 16.04' and 'Raspbian GNU/Linux 9 (stretch)' and both produced the same error.
Right after I installed Openvino 2020, I did the following commands to check if the cv2.TrackerCSRT_create() module exists:
python3 import cv2 cv2.TrackerCSRT_create()
and an error would be thrown
AttributeError: module 'cv2' has no attribute 'TrackerCSRT_create'
Checking the cv2 version that i am using by writing cv2.__version__, it would show
'4.2.0-openvino'
David_C_Intel
Hi ECruz8,
Thanks for your patience.
Extra modules from OpenCV (opencv_contrib) are not included as part of the OpenVINO™ toolkit. However, you can rebuild OpenCV with extra modules and point OpenVINO™ toolkit to your custom build by modifying the setupvars script.
David C.
