6575 讨论
How one NCS device load tow graph all at ones
员工
1,619 次查看
Could NCSDK V2 do it ? And where could I find an example
0 项奖励
6 回复数
员工
1,361 次查看
0 项奖励
员工
1,361 次查看
@PINTO
Thanks for your advise. I wanna implement MTCNN with one NCS device, are you familiar with this? could you give some advise ,pls.
0 项奖励
员工
1,361 次查看
@curry_best
I challenged with @zufeifei.
Implementing MTCNN with NCS has various problems.
https://ncsforum.movidius.com/discussion/1093/how-to-assign-multiple-graph-files-to-one-stick
  1. Although MTCNN generates multiple outputs from one model, NCS can only output a single output.
  2.
  3. NCS does not support "PRelu" layer.
  4.
  5. NCS can not change the input resolution.
  6.
So I do not recommend implementing MTCNN with NCS.
0 项奖励
员工
1,361 次查看
@PINTO
I have finished reading your discussion. And I see you use a more complex repository than this one :
https://github.com/movidius/ncappzoo/tree/master/tensorflow/MTCNN
It was modified, simplified for NCS. Are you interested in trying?
0 项奖励
员工
1,361 次查看
@curry_best
I know the existence of that repository.
And it has also been verified that the repository does not work on "NCSDK v2".
When "NCSDK v2" is used, I know that it will not work properly unless it is a program of the following repository.
https://github.com/movidius/ncappzoo/tree/ncsdk2
"master" branch = NCSDK v1
"ncsdk2" branch = NCSDK v2
You will notice that MTCNN does not exist in ncappzoo [v2].
0 项奖励
员工
1,361 次查看
@PINTO
Oh… it seems like 'NCSDK' have some troubles with MTCNN. I have to find other solutions. thks for your time to discussion MTCNN.
0 项奖励
回复
