6605 Discussions
How to fix an OpenVino error during Pynq-Z1 installation.
bben011
Hello
I need to get my NCS2 running on a PYNQ-Z1 board. As the OpenVINO installation is mandatory to get the NCS2 detected, I decided to try the installation the OpenVino toolkit used for the Raspberry under a Raspbian Os, by following the tutorial of the link below:
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_raspbian.html
I successfully installed the OpenVino without any errors. I have also successfully built and run the object detection sample. When I try to run my example, I got this error:
- ModuleNotFoundError: No module named 'openvino'
if I use: from openvino.inference_engine import IENetwork, IEPlugin instruction
- ModuleNotFoundError: No module named 'armv7l'
If I use: from armv7l.openvino.inference_engine import IENetwork, IEPlugin instruction.
I have tried the same example on a Raspberry Pi 3 and it works.
Is there any suggestion on how to fix this error.
Thank you !
David_C_Intel
Hi bben01,
Thanks for reaching out.
Please try building OpenVINO™ toolkit from source using this guide and see if the error still happens.
David C.
bben011
Hi DavidC
Thank you for your quick reply, I will try the installation according to the guide and let you know.
Bests regards
