6577 Discussions
How to install Movidius with Python 2 environment?
The default Movidius is install Caffe, TensorFlow with Python 3 environment.
If I want to install with Python 2, what can I do?
@miily Python 2.7 support is already integrated. Please see the NCSDK v 1.12 release notes.
@Tome_at_Intel Thank you.
I tried it and found that python 2 can import mvncapi, but can't import cv2, caffe, and tensorflow (maybe because they're installed on python 3)
If I want to use them on python 2, how can I do?
@miily Can you provide some information about your host system? Also try going to your Ncappzoo/tensorflow/inception_v1 directory and do a make. Then try the following command python2 run.py.
@Tome_at_Intel
I did make in ncsdk/example/tensorflow/inception_v1 directory and tried python2 run.py. I got below error.
File "run.py", line 22, in
import cv2
ImportError: No module named cv2
and when I use python3 run.py, it is successful execution like below:
Number of categories: 1001
Start download to NCS…
inception-v1 on NCS
547 electric guitar 0.97314
403 acoustic guitar 0.011787
883 vacuum, vacuum cleaner 0.0058098
421 banjo 0.0034828
492 chain saw, chainsaw 0.00058222
Finished
@miily Try pip install opencv-python and then trying python2 run.py again. Let me know if this works for you. Thanks.
@Tome_at_Intel It's works, thanks for your help.
@miily You're welcomed!
