i use:
- win OS
- OpenVino 2019 R3
- VPU:EDL-mPCIe-MA2485
- Mustang-V100_win64_Plugin ( i use Service Configuration in https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_windows.html)
i run :
demo_security_barrier_camera.bat -d HDDL
i have error :
[ INFO ] InferenceEngine:
API version ............ 2.1
Build .................. 30677
Description ....... API
[ INFO ] Files were added: 1
[ INFO ] C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\car_1.bmp
[ INFO ] Loading device HDDL
hid scan
Failed to use HDDL BSL configure file in ${HDDL_INSTALL_DIR}/config,
it may not exist or format is wrong
Error is: BSL_ERROR_NO_DEVICE_FOUND
Automatically detect reset device...
hid scan
scan F75114 device...
found 0 F75114 device
scan ioexpander device...
found 0 ioexpander device
scan mcu device...
found 0 mcu device
bsl init failed for: BSL_ERROR_NO_DEVICE_FOUND
HDDL
HDDLPlugin version ......... 2.1
Build ........... 30677
[ INFO ] Loading detection model to the HDDL plugin
hid scan
hid scan
scan mcu device...
found 0 mcu device
hid scan
hid scan
scan mcu device...
found 0 mcu device
hid scan
hid scan
scan mcu device...
found 0 mcu device
Reset all devices with device type 4
[1;31;40m[10:01:07.3786][3088]ERROR[ServiceStarter.cpp:55] Error: Wait HDDL Service Ready failed.[0m
[1;31;40m[10:01:07.3791][3088]ERROR[ServiceStarter.cpp:29] Error: Failed to start HDDL Service[0m
[1;31;40m[10:01:07.3816][3088]ERROR[HddlClient.cpp:244] Error: Failed to boot service.
[0m
[ ERROR ] _client->query(QUERY_TYPE_DEVICE, &query) failed: HDDL_NOT_INITIALIZED
Error
thank you
Your HDDL drivers are not installed.
Please confirm that you have followed additional installation steps to install HDDL drivers.
After installation, can you please go to "Device Manager" and check if you can see Movidius Myriad X under "Universal Series Bus Devices"? If so, please try running the demo again.
Hope this helps,
Mecit
